84 944
Spare tire tie down
I got a spare tire tie down for my 84 but I can't find anything to screw it into. I can't imagine Porsche would just leave the spare loose like that. Is there a bolt hole?
Old 01-06-2013, 03:09 AM
My 86 has a bracket on the inside rear panel that has two captive nuts the the spare tire tie down. One is for use the the collapsible spare and the other for a conventional tire. If you cannot find it I can take a photo.
Clifton
Old 01-06-2013, 07:36 AM
ernie9944's Avatar
Look carefully in the spare cubby hole.There should be a receiver were your tie down will screw in . Pics is of a my 968 spare cubby hole but 944 should be the same,the jack should be located behind the spare when you tie it down so it doesn't flop around.OEM tie down for a 84-944.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 01-06-2013, 09:15 AM
