'68 911 / '86 944
Should I fix my broken brake booter check valve?
Today I accidentally broke the small vacuum line attachment on the brake booster. I assumed I needed to replace the part. Looking at the parts list it appears to be tied to the AC. I have stripped the AC from my car. Do I need to fix it? or just cover the hole with epoxy and go on. What do you think?
Old 03-24-2013, 01:40 PM
9FF 9FF is offline
9FF's Avatar
iirc it supplies a vacuum canister by the battery and that in turn controls ALL your heater/AC valves, vents and switches under the dash. If you don't have heat or AC I don't think it would matter.
Personally I would fix it, it's a cheap and easy swap.
Old 03-24-2013, 02:41 PM
Fix it, as it operates other things besides the above. See diagram below.
944 Online Forum - The Porsche 944 Forum For The 944 Enthusiast.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 03-24-2013, 02:46 PM
Mudd's Avatar
Larry, where is the brake booster check valve in your diagram and does my 1987 na have a carbon canister.
1978 924 The Grey Ghost - 18,000 miles and counting
1987 944 Black Betty - Bringing back from years of abuse
Old 03-24-2013, 03:09 PM
Banned
I think that vacuum reservoir thing also is the only thing keeping your brake assist working if the car happens to stall out when moving.
Old 03-24-2013, 03:52 PM
477 611 933A, Available at Pelican. Been there.....
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 03-24-2013, 04:57 PM
If your car is early the fan controls aren't operated by vacuum as you can probably tell by how they feel. Mine snapped off on my early car and I deleted everything
Old 03-24-2013, 05:10 PM
Hi Andy, Found a better picture of the Vac Hose Routing. Search is a powerful tool.
vac line in my 1986 944?????
Cheers,
Larry
Old 03-24-2013, 08:54 PM
