'68 911 / '86 944
Should I fix my broken brake booter check valve?
Today I accidentally broke the small vacuum line attachment on the brake booster. I assumed I needed to replace the part. Looking at the parts list it appears to be tied to the AC. I have stripped the AC from my car. Do I need to fix it? or just cover the hole with epoxy and go on. What do you think?
iirc it supplies a vacuum canister by the battery and that in turn controls ALL your heater/AC valves, vents and switches under the dash. If you don't have heat or AC I don't think it would matter.
Personally I would fix it, it's a cheap and easy swap. |
Fix it, as it operates other things besides the above. See diagram below.
944 Online Forum - The Porsche 944 Forum For The 944 Enthusiast. Cheers, Larry
Retired USAF and Civil Service, 1985.5 NA Graphite Metallic, A never ending work in progress, 1992 968 Horizon Blue Cab "New Toy" ![]() |
Larry, where is the brake booster check valve in your diagram and does my 1987 na have a carbon canister.
1978 924 The Grey Ghost - 18,000 miles and counting 1987 944 Black Betty - Bringing back from years of abuse |
Banned
I think that vacuum reservoir thing also is the only thing keeping your brake assist working if the car happens to stall out when moving.
477 611 933A, Available at Pelican. Been there.....
Jon
87 924S 82 924-Gone. 80 924 parts car-Gone. |
If your car is early the fan controls aren't operated by vacuum as you can probably tell by how they feel. Mine snapped off on my early car and I deleted everything
Hi Andy, Found a better picture of the Vac Hose Routing. Search is a powerful tool.
vac line in my 1986 944????? Cheers, Larry
Thread Tools | |
Rate This Thread | |
