gmorken's Avatar
ignition switch component question
I'm not looking for instructions for removing the ignition on a late 944 as there are plenty of resources that people have been kind enough to submit to the various boards. Mine is a slightly different academic-like question...
I haven't found a message post yet identifying the common failures within the overall ignition assembly and to determine which specific internal component has actually failed.
Here are the specifics:
  1. key turns fine with no binding
  2. it starts fine but has no internal spring loaded motion to return it counterclockwise so I have to manually turned the key away from the start position
  3. when the key is turned to the off position, sometimes it acts like it only traveled to the ACC position as opposed to the full OFF position.
Am I just thinking to much on this topic??? Do people normally just replace the entire subassembly? Part of my issue is likely the electrical component but what component provides the spring back from start position function?
Thanks!
1985/2 944 Alpine White, Fuchs
Musik Stadt chapter of PCA
Old 04-07-2013, 07:26 AM
Just thinking out loud
mattdavis11's Avatar
replace the plastic electrical portion of the switch, it has cracked
91 FJ80
84 Ram Charger (now gone)
Old 04-07-2013, 11:16 AM
gmorken's Avatar
Thanks!
But its only 28 years old??? Thanks - appreciate the info...
Old 04-07-2013, 11:45 AM
porschetub's Avatar
They are a VW part around $10 from memory,go for it.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 04-12-2013, 11:06 PM
