Porsche 944S Club Sport
To All:
I'm in the process of doing this modification in my stock AFM Setup (Temporary, until i finalize the MAF programming a few days). It the vortex Generator mounts within the AFM Inlet adapter (no oem airbox) setup. This should improve air flow and throttle response before it contacts the AFM trap door. Will post pics later today.Later...
Guru944 ![]() 2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport. 1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo. http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions. Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful. |
No.
V2:
Why not? Air never travels in a straight line but in waves like ribbons. This is going into my OEM afm unit not my new MAF converson sensor,where it would cause errors in reading density..... Please elaborate? Later...
Throttle response is largely determined by the distance between the intake valve and the throttle blade. Related is the amount of restriction in the air path. Just about anything short of WOT leaves the AFM door with a very small opening so there's not much to be gained ahead of the AFM.
IF you find a dyno test to prove a power gain I wouldn't go there,after all there are companies advertising 8 bhp gains from a pod filter ??????.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
non-whiner
You'll be better off installing a computer ventilation fan on the intake. Poor man's blower really rocks! Pull up to the light next to that new viper. Give him a cocky nod as you switch on that bad boy, jamming massive air into your engine. That viper driver never saw anything like your badass ride!
Cone Chaser
AFM #725
Actually these two guys on YouTube gained a couple HP using two leaf blowers
Self-Proclaimed Newb
How much power do you think you'd gain from adding one of these:
![]() I'm sorry, that was mean. =( I am interested in this, actually. There are enough flame wars already about the effectiveness vs. ineffectiveness of altering the air intake path. On the one hand, the logic is sound; on the other, it is unreasonable to expect such cheap power gains. So I'm always on the edge of my seat waiting for one of these home brew mods to work substantially.
Current: 1986 944 Turbo - Sapphire Past: 1983 944NA - Black (RIP) 1985.5 944NA - Guards Red (in purgatory) 1985.0 944NA - Maraschino Red (traded for a Volvo 244 )
AFM #725
They don't work at all. Sorry
I've heard of decent power gains obtained from devices that force more air into the intake........ some are powered by the car's own exhaust gases (imagine that!) others are belt driven.
1986 944 NA Sapphire Metallic http://944porsche.blogspot.ca/ |
Not exactly force induction but on the 968 the intake plenum contains two separate inductions paths,one for low speed operation and a second one for engine speed over 4,000 RPM.At that speed,a bypass tube in the intake direct the air flow into the high speed passage to provide a super charging effect to the intake mixture.Taken together the duel-path plenum and the VarioCam does help explain why the 968's off-idle provide such an immediate and satisfying whump to the small of your back.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
don't mean to p*$$ on your parade
but vortex devices are an utter waste of money and the only hp's gained reside between the ears so to speak. there is absolutely no basis to presume that these devices 1. create a lasting vortex and 2. that this has a positive effect on either throttle response or mixture. besides, the barn-door style AFM will always be slower than an MAF sensor setup. If you want razor-sharp throttle response you'll need to convert to individual throttle bodies and a tuned intake plenum (like the E46 M3 CSL). I'd much rather invest that sort of money somewhere else, though...
non-whiner
What???...really???
haha yes, hope I didn't burst your bubble
Mainly, these "As seen on TV" performance products make wild claims of horsepower, torque, and fuel mileage that are all complete lies for a normal car. If there is any shred of truth to any of thier claims, it may be on a car that is set up to accentuate the positive of what the product can do (Maybe on a carbed car with a cold air intake tube that dumps directly into the carb with no restrictions). I just bet that the only place any of these claims were seen as truth is in a closed, controlled enviroment where the car is hooked up to many sensors, tubes, and meters that can all be tweaked to show whatever they want
Tornado is a complete waste of money on 99% of the cars on the road ! |
AFM #725
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Triple T
ernie9944:
Yes, the 968 unit is dual resonance intake system. I already upgraded to this with big power gains above 3500rpm. It is better then the S2 intake and much better than the stock S oem Mg intake. Looking for more hp Na before the final MAF and Turbo setup... Later....
