cro-cro's Avatar
Sway bar bushing replacement
The other day I heard a little thumping in the front left suspension. I looked under and saw the sway bar bushing was not all there. I've tried to find something online about what it takes to replace and haven't found anything. I figured it would be worth it to replace both at the same time. What all takes place in replacing the sway bar bushings?
Old 06-19-2013, 04:32 PM
AFM #725
Gawernator's Avatar
Take off bar, cut off old bushings, slide on new ones (I used silicone for lube) lol
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 06-19-2013, 04:42 PM
cro-cro's Avatar
Do I need to get a caliper to figure out which set of bushings to get?
Old 06-19-2013, 05:03 PM
AFM #725
Gawernator's Avatar
Better safe than sorry if you aren't sure of the size
Old 06-19-2013, 05:19 PM
cro-cro's Avatar
It's tool time.
Old 06-19-2013, 05:24 PM
9FF 9FF is offline
9FF's Avatar
You don't need any tools. Wrap some masking tape around it and mark off the circumference. Take the tape off and measure with a ruler. The size (diameter) of the sway bar = circumference you just measured / 3.142
Old 06-19-2013, 06:58 PM
AFM #725
Gawernator's Avatar
A ruler is a tool
Old 06-19-2013, 09:13 PM
Toofah King Bad
Rasta Monsta's Avatar
HA or you could slip an open end wrench or two over the bar!
Originally Posted by Gawernator View Post
A ruler is a tool
So is a calculator!
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 06-19-2013, 11:07 PM
