| View Poll Results: Do you think she'll run??? | |||
| YES |
4 | 40.00% |
| NO |
6 | 60.00% |
| Voters: 10. This poll is closed | |||
LinkBack | Thread Tools | Rate Thread |
Do you guyz think she'll run?
{1987}944S - (SOLD). |
She's TOAST!!! Will not start. I got TDC on the flywheel and the cams, then I put the timing belt back on. I used a long screw driver to see if piston #1 was up all the way. I didn't know the piston ends up that hig in the cylinder! Anyway, I assembled the DIS rotor and CAP. I put the plugs in nice and snug. I put the wires on the DIS cap in the correct order and gave it a go. She didn't budge. I could smell gas in the muffler. Well, she's a dead stick for now. I don't know what I want to do with her. I am definitely getting my 951, so I sell her for real cheap to the highest bidder or keep her and fix her WAY down the road after the 951. I could part her out and keep whats good and sell the rest to people in need. It's just that she is so beautiful
If I kept her, I don't think I could afford insurance for both the cars. I dont know. I think I'll keep her for awhile. Quick question, Why would they make it so that the valves and the pistons would hit if timing belt broke? Why couldn't they inset the valves a bit so they would clear the pistons in case it did happen? Because,... it would be to perfect and it would be devastating on the autoparts industry? HMMM
{1987}944S - (SOLD). Last edited by overkill; 07-28-2002 at 07:37 AM.. |
compression+German engineers=don't shadetree the important stuff
*Disclaimer: The person above is actually dumber than he appears. my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements '84 944 auto/ps/ac/cc '86 951 Providing ignorance one post at a time. |
Most engines nowadays are "interference", that is if the belt or chain breaks the valves hit the pistons (ask any Saab V6 owner ). To achieve the sort of power outputs the compression ratio, piston and combustion chamber design leave little room for mechanical failures. Interestingly enough, there is a trend now to go back to timing chains and away from timing belts........
By the way, your car did not fail; you broke it!!! Most timing belt failures could could be avoided with correct maintenance. We currently have a '86 944 with 122,000 miles on it, no-one knows when the belt was changed, and, suprisingly enough, the belt broke. Now let's see, it's either $350 for a belt change or $2,500 to repair all the damage, which one would you choose????
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
Halleujah and amen. (I was one of the 2 that voted, no it won't run again) AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
i must be missing something here but what makes you think it is broke? is the engine turning over real fast? have you done a leakdown? it could be something simple like the hal sensors being hooked up backwards.
did the belt break or something? if it did you can bet that the valves are bent. even if it was not running, just cranking.....they are bent.
84 944(sold) 85 944 86 951 87 944(sold) 87 951 88 951 Turn up the BOOST!!! |
As far as I am concerned; there never is a "simple job" and you should always make notes. Even simple jobs can become major ones..............................................
SoCal; $350 is for parts and labor!!!
I agree with Brit......I remember doing a "simple" job on my 82 plymouth sapporo (aluminum block as well)
Tune up went bad....stripped one spark plug.....AAAAGGGGHHHHHH That is why I only use a torque wrench nowadays! ..... another reason (#212)...a porsche should not be a first car for anyone.
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
porsches are great d d's
i drive my 944 everyday 120 miles total to and from work i keep a creeper and jack where the jump seats should be
