Yep, that color is what Porsche calls "Light Gray" But it's really more of a tan/beige. I call that color greige. It's a very common color from 85.5-87.
Wow, I don't think I have seen "light gray" script seats. That's awesome and it looks like they are in good shape too. Very cool.
www.Only944.com Porsche parts, Only better, Only944 87 944 N/A 165,000 miles 84 944 Saved by God, because I could not. |
mine is 1984 , all interior is brown
code on sticker says LU i dont know is it original or not |
Yep, LU is Brown.
Antipurist
So if anyone has a light grey carpet set for sale, let me know
![]() Is the information solely under the carpet or is there anything relevant on the spec sheet that has been next to my tool kit for over 30 years!
1987 944 Summer 2006 E90 Winter |
Wasn't sure if you had gotten this one or not, but here's mine:
1987 944 Turbo Listed as "Burgundy" on the original window sticker, color code in the trunk is YZ. ![]() ![]()
Here's my 87 924S's options decal.
Guards Red Exterior (not my fave) with Linen/Brown Vinyl/Script seats, dark brown dash and door top trims. I'll ask the question in a separate thred, but if anyone has researched the best interior paint match for the dark brown dash, I'd be grateful for any results. cheers, John |
My ex 83 -944 had a beige ...brown interior code 3ff.
![]() ![]() ![]() Speakers install in the rear wheels wells.![]() .
Caraquet,N.B. Canada. |
Making interior color code list is very good idea. I was already searching but couldn't get any good results. Thanks for discussing and sharing this topic.
Does anybody has seen CB as interior code? It is on the sticker of mine P924S from 1986.
Regards Govert |
Just don't apply it too thick, several light coats will look much better than one thick coat.
Good luck, George Beuselinck |
Thanks George, at this, having spent a nutty amount of time on it, removing most of the vinyl and building it uper, shaping and surfacing (60 HRS +), my dash is now in epoxy primer; next I plan on applying SEM Texture Coat, then their Color Coat, custom mixed at a local paint jobber. It won't he stock (no faux-leather grain) and it won't be perfect-perfect (recreating details in filler is tough) but it should be OK. Famous last words. Thanks very much, John
I just realized some about my interior: it’s Linen and Black, not Linen and Very Dark Brown. John
Anybody knows the interior code for the 944 Turbo Silver Rose?
![]() ![]() TIA
I have an 87 924S in the common Porsche Light Grey or Greige “XP” .. seats are Porsche Script, Drivers isn’t in great order ... I came across these Sports Seats from a 944 of same era & hoping, even though they are a different design, that they’ll look OK once fitted .. color seems correct :
If this is still of interest: My 11-'85 924S has interior code 'AB', is Alpineweiss (L90E) and this is the seat combo: black vynal sides and porsche script cloth center in some sort of purple? (maroon?)
Yep, we are still interested in interior color code, thanks. I am still compiling a list of the color code/seat options and this is helpful.
I have seen the color code AB once before and the seats were black with black script inserts. So I would assume that your script material used to be black when it was new and has just faded over the years. I could be wrong, but I don't think they ever made purple script material.
Well, the car was 37 years with the previous owner and I am pretty sure he did not swap interiors. Rear seats have the same fabric, but also some weather damp on them atm as the car stood outside for a long time.
Maybe its a European spec only? or an option? I am not good with the option codes, but maybe someone is? Here are some more pics of the tag and interior. Its difficult to get good color in LED inside lighting though.. ![]() ![]() ![]() ![]() Edit: I think you are right though: someone else also stated that color was not delivered and must have been the influence of UV! Last edited by Beetspeed; 11-30-2025 at 08:36 AM.. |
