944play's Avatar
Unhappy something went wrong
SO im cruisn down the road just chillin in fifth gear and all of a sudden a big clunk and no movement. I had the transmission linkage at the shift lever go out the other week so i check that first and all is well there. What is more likley to go out in an '83. a transmisson or the differential?? any help would be greatly appriciated.
Old 12-10-2002, 05:32 PM
Mike B's Avatar
"Big Clunk"...Yikes, that could be a lot of things...Clutch, tranny, CV joints...
Could you get it into gear after the clunk...Was the clutch pedal fine...Did you have a look under the rear of the car...Does it work in any gear...
Old 12-10-2002, 05:43 PM
944play's Avatar
I imagine that the clutch is fine never had problems with it and the engine was out of the car not too long ago, im sure it would have been noticed if it was wearing out, the clutch pedal is the same i cant think of what have went wrong with it, and i can feel the car go into gear, but somethings not making it to the ground.
Old 12-10-2002, 05:52 PM
88_944's Avatar
Oh man, I think it's not your Clutch or CVs because they don't go out like that. It's worst, It's your tranny gear.
Humm... let's see here....
My Black 944
My Gaming Forums. Xbox360gen.com
Old 12-10-2002, 06:01 PM
AFJuvat's Avatar
almost like you are in neutral?
Sounds like a clutch - a CV should be pretty easy to spot.
Worst case, R & P, but usually they give some warning before they go
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 12-10-2002, 06:02 PM
944play's Avatar
Allright, I narrowed it down to the differinitial. I jacked the rear end up and spun one of the tires, the other one diddnt spin. i am assuming the lsd is history. any one have a turbo rear end for sale??
Old 12-10-2002, 09:16 PM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
I understand that the LSD's were few and far between. Verify that your is a LSD before making that call. It might save you a couple of dollars.
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 12-12-2002, 11:55 AM
