Replace late model ignition switch
I am about to rule out an ignition switch issue and realized that the clarks guide to replacing this does not cover the newer cars. Does anyone remember seeing a write up on how to change out the ignition switch in a NON 924S/early model?
peter 1991 944S2 Cab, Crystal Silver Metallic "Platinum Banshee" 1987 944S Alpine White, Ice Shark Lights "Desert Ghost" 2015 Charger R/T Road & Track |
In the Fires of Hell.....
It's pretty much the same. Two screws at the back of the switch you need to remove.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
The best way is to remove the steering wheel and instrument cluster an access that way. Ask me how I know. You must use a very short screw driver to get the screws loose as there is only a couple of inches of clearance to get at them. A phillips screwdriver bit in a 1/4" socket with 1/4" drive ratchet was my weapon of choice. If your car has an airbag, disconnect the battery. On second thought, disconnect the battery anyway when doing this procedure.
