Electrical problem on fuse #7
The battery was going dead after just a few days after it was charged. I disconnected the positive battery terminal and connected a test lame between the terminal and the battery cable. With every thing off and doors closed , the test lamp blinked at the frequency of the turn signals. I removed fuse #7 and the blinking stopped. I have no idea of where to go next. It seems that the problem is down stream of the fuse. Has anyone had this problem?
Electrical Problem on FUSE #7
Here's my prior post with links for download: Porsche Workshop Manuals & Parts Catalogs BTW, I had a similar issue (battery drain) that I traced to the tiny "buzzer contact switch" as Porsche labels it, in the steering column housing; next to the ignition switch. This is the switch that gives power to the door alarm relay (G-16) whenever the key is inserted in the ignition lock. Since it does not engage the worn key mechanism correctly, the buzzer relay is always energized even when the key is not inserted in the switch. The relay continuously draws about 250mW of current so the battery will loose cranking power in a few days unless a trickle charger is used.
======================== Original owner, 1986 944 Guards Red/Black |
Long Time Porsche Owner
No Volume 4 Electrical Workshop Manual at that link
![]() Anybody else have a link to Volume 4 of the workshop manual? I'm tracing down electrical gremlins too. Thanks! Ted
Cheers! Ted '86 Silver 944 N/A - Forever in restoration! |
In the Fires of Hell.....
Please realize that putting links to what are illegal copies of Por$che copyrighted material on this site puts our host at legal risk....
Read the terms and conditions, please.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
A common battery drain culprit is the door switch. When the door is opened and closed it de-energizes the window relay circuit. A faulty door switch will leave this relay energized and run down the battery.
BTW what is fuse #7 for? |
http://www.renegadehybrids.com/OTHER/944wiring/Vol4-electrical.pdf
FUSE #7 is for the clock, interior lights, radio, and cigarette lighter |
Thanks Leo, got the link & found the download.
OK, if the you have an aftermarket stereo on fuse #7 it might be causing the drain. The stereo amplifier may be staying on after engine shutdown, and drawing current through the memory power lead, or other weirdness. Check the current draw with and without the stereo connected.
