Electrical problem on fuse #7
The battery was going dead after just a few days after it was charged. I disconnected the positive battery terminal and connected a test lame between the terminal and the battery cable. With every thing off and doors closed , the test lamp blinked at the frequency of the turn signals. I removed fuse #7 and the blinking stopped. I have no idea of where to go next. It seems that the problem is down stream of the fuse. Has anyone had this problem?
Old 08-08-2016, 10:21 AM
Electrical Problem on FUSE #7
Perhaps a related issue, the alarm (key in the ignition) stays on even while driving. this seems to be the same rate as the test lamp flashing.
Old 08-08-2016, 12:12 PM
Suggest you download volume 4 - Electrical workshop manual.
Here's my prior post with links for download:
Porsche Workshop Manuals & Parts Catalogs
BTW, I had a similar issue (battery drain) that I traced to the tiny "buzzer contact switch" as Porsche labels it, in the steering column housing; next to the ignition switch. This is the switch that gives power to the door alarm relay (G-16) whenever the key is inserted in the ignition lock.
Since it does not engage the worn key mechanism correctly, the buzzer relay is always energized even when the key is not inserted in the switch. The relay continuously draws about 250mW of current so the battery will loose cranking power in a few days unless a trickle charger is used.
Original owner, 1986 944 Guards Red/Black
Old 08-08-2016, 01:04 PM
Long Time Porsche Owner
jollyted's Avatar
No Volume 4 Electrical Workshop Manual at that link
Anybody else have a link to Volume 4 of the workshop manual?
I'm tracing down electrical gremlins too.
Thanks!
Ted
Cheers! Ted
'86 Silver 944 N/A - Forever in restoration!
Old 08-08-2016, 01:41 PM
In the Fires of Hell.....
kdjones2000's Avatar
Please realize that putting links to what are illegal copies of Por$che copyrighted material on this site puts our host at legal risk....
Read the terms and conditions, please.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 08-08-2016, 01:49 PM
A common battery drain culprit is the door switch. When the door is opened and closed it de-energizes the window relay circuit. A faulty door switch will leave this relay energized and run down the battery.
BTW what is fuse #7 for?
Old 08-08-2016, 03:14 PM
Thanks!
Ted
I think you missed it... here's a direct link:
http://www.renegadehybrids.com/OTHER/944wiring/Vol4-electrical.pdf
Old 08-09-2016, 06:10 AM
FUSE #7 is for the clock, interior lights, radio, and cigarette lighter
Old 08-09-2016, 06:48 AM
jollyted's Avatar
Thanks Leo, got the link & found the download.
Cheers! Ted
Old 08-09-2016, 11:17 AM
OK, if the you have an aftermarket stereo on fuse #7 it might be causing the drain. The stereo amplifier may be staying on after engine shutdown, and drawing current through the memory power lead, or other weirdness. Check the current draw with and without the stereo connected.
Old 08-09-2016, 01:02 PM
