Cam Timing..can advancing/retarding help performance?
Should I advance or retard my cam for better performance? I am in the middle of my belt replacement, so I figured now would be a good time to ask. My car has the regular bolt ons (chip/one off cold air intake, supertrapp muffler) is there like a tooth change that may help? I drive in all rpm's...and will run 17's with a low pro tire (smaller than stock).
Thanx,
Greyson
Yes the motor is in the front....
Old 01-05-2003, 11:30 PM
SoCal Driver's Avatar
NO!
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-06-2003, 12:22 AM
ehh..just did some searchin. I see that it's too close for interference to occur. Thanx though.
Old 01-06-2003, 12:40 AM
AFJuvat's Avatar
...and here class, we see SoCal demonstrating the ABC's of proper replies to questions:
A: Accuracy - his answer is indeed 100% accurate.
B: Brevity - No wasted words, direct and to the point.
C: Clarity - No doubt at all what he meant to say.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 01-06-2003, 03:57 AM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
AFJuvat
Now I see where I went wrong. Point A, Accuracy: Seldom more than almost right, usually wrong to the point of flirting with lawsuits against me.
Also, take note of B. Brevity: Closest thing I get to that is "Beverage", alas the more of that I have, the less concerned with brevity I become.
I also feel compelled to round it off by realizing that I understand to get the gist of the meaning to the point C. Clarity. Seldom do I even know what the hell I'm saying, let alone anyone trying to wade through my abysmal sentance structure. (If a pile of ruble can be construed as "structure"). To quote So Cal's reply to a recent post of mine: "What?".
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 01-06-2003, 07:16 AM
But!!!
You can get the cam from the later model 944 NA's and put it on the early heads. Gives you a bit more exhaust timing. Some have custom grind cams; would be interesting to hear from them.
In the late 70's when I actually had a new 924, I was looking at a few performance enhancements other than down hill in a stiff breeze. One of these was a means of advancing the cam with a lever in the cockpit or a centrifugal counter weight advancement system.
Old 01-06-2003, 10:07 AM
