Cam Timing..can advancing/retarding help performance?
Should I advance or retard my cam for better performance? I am in the middle of my belt replacement, so I figured now would be a good time to ask. My car has the regular bolt ons (chip/one off cold air intake, supertrapp muffler) is there like a tooth change that may help? I drive in all rpm's...and will run 17's with a low pro tire (smaller than stock).
Thanx, Greyson
Yes the motor is in the front.... |
NO!
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
ehh..just did some searchin. I see that it's too close for interference to occur. Thanx though.
...and here class, we see SoCal demonstrating the ABC's of proper replies to questions:
A: Accuracy - his answer is indeed 100% accurate. B: Brevity - No wasted words, direct and to the point. C: Clarity - No doubt at all what he meant to say. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Now I see where I went wrong. Point A, Accuracy: Seldom more than almost right, usually wrong to the point of flirting with lawsuits against me.
*Disclaimer: The person above is actually dumber than he appears. my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements '84 944 auto/ps/ac/cc '86 951 Providing ignorance one post at a time. |
But!!!
You can get the cam from the later model 944 NA's and put it on the early heads. Gives you a bit more exhaust timing. Some have custom grind cams; would be interesting to hear from them. In the late 70's when I actually had a new 924, I was looking at a few performance enhancements other than down hill in a stiff breeze. One of these was a means of advancing the cam with a lever in the cockpit or a centrifugal counter weight advancement system.
Thread Tools | |
Rate This Thread | |
