944 trailing arm
I am about to help a friend change the rear wheel bearings. While we have the trailing arm off, what else would it be "the perfect time" to change also? like shocks/bushings/etc?
thanks everyone Rob 78 924 na 82 280zx na |
Timing belt.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
I am talking about other stuff under the rear in the vicinity of the trailing arm that are easier to deal with when the trailing arm is out of the way.
thanks |
rear bearing, seals, brake hoses, clean/regrease cvs. may consider turning the rotors while you hace them off
hint: if you are going to heat up the hub to install the bearings, remove the rotor first - otherwise it acts like a heat sink AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Rennlist Member :)
2006 Subaru Impreza WRX STI 1989 Red Devil F440 Former: 1987 Porsche 944 |
