Struts
I'm in the process of pulling the struts on an 87 924S so I can replace the inserts. I'm probably going to go with KYB as I read Gabriels aren't worth installing. Will the strut mounts also need to be replaced? The drawings I see actually have two items called "mounts", one being a bearing surrounded by rubber (944 343 071 00) and the other resembling a flange which appears to be NLA.
Thanks for any input |
no you don't need to replace those, typically.
if you do need new ones you can use vw fox strut bushings to replace with yours.
The cars we drive say a lot about us. 1987 Porsche 924S - RIP 1985.5 Porsche 944 Lux - Daily Project 2002 Mercedes-Benz C320 Sportswagon - Daily Problem |
Politically Incorrect
When you disassemble your struts, remove the "bearing surrounded by rubber".
It will push out because it is not bonded to the "flange". Place a straight edge across the top and take a measurement from the bottom of the straight edge to the top of the bearing housing. Measurement new is around 10mm - if you have less than 5mm, I would consider replacing. I say consider because they cost about $100 each.
Edek '87 924S '91 535i |
I have had the Monroe 901941 VW Fox mounts installed for about 6 months now (******** has them for $2.98 each).
When i disassemble my struts to install the new Bilstein B6's, I will report on how they actually held up on a 924S. Regardless, they will not be reinstalled (just an experiment) and will be replaced by polyurethane strut mount bushings (yes, another experiment). Unfortunately the 535i threw a "Brake Light Circuit" fault message, so I had to troubleshoot that instead of installing struts on the 924S.
Edek '87 924S '91 535i Last edited by onZedge; 07-05-2017 at 02:10 PM.. Reason: forgot spelchek |
12.98, (which is what I see the Monroe's for) certainly beats 94.00. Now that I have the struts out (whew!!) per Clark's, I'm taking them to a shop to replace the innards rather than use a spring compressor. Worth it for peace of mind, I think.
Thanks for the input, folks |
You can actually use the car as spring-compressor.
AutoZone also has tool-rental programme for free. Their spring-compressor is actually decent. |
Back from Beyond
It's actually easier and safer without a spring compressor. There are lots of tutorials on how to do the strut change, so Google is your friend. You will NEED a rattle gun to remove the upper strut mount nut. It's a locking nut, so one use only.
Linky: http://www.924board.org/viewtopic.php?t=33966&highlight=
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! Last edited by Slam; 07-12-2017 at 01:34 PM.. |
Take care Ernie
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
You can also grind a couple flats on an old socket and turn it with an adjustable wrench.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
even easier...
use an oxygen sensor socket on the strut nut.
Another way to tighten strut nut
If the top of the strut shaft has a hex socket, use an allen key to hold the shaft, and tighten the nut with a 22mm oxygen sensor socket:
Great minds think alike!
Edek '87 924S '91 535i Last edited by onZedge; 07-13-2017 at 03:44 PM.. Reason: Actually placed fist on screen - nothing happened... |
Back from Beyond
BTDT. From Vice-Grips on the strut itself to stop it rotating, to deep offset box-end wrenches like the one pictured, I've tried plenty of different ways not only to get that top nut off but also to torque it down properly. In the end, the rattle gun made life so much easier. And faster.
YMMV
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
The vice grip method will loosen up every time, the strut rod metal is too hard to grip so you won't be able to get the nut tight enough. It takes two wrenches to tighten it enough if doing it with hand tools, one on the nut and one on the strut rod top hex or allen. So if you don't have a rattle gun you can get an offset wrench for $10 on Amazon and have piece of mind.
