Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
Porsche Crest 928 Engines specs FAQ
YEAR --MODEL --COUNTRY --DISPLACEMENT -- INJECTION -- COMP --POWER
78 ------------------- US - -- 4.5 (4,474) 95/79 - K JETRONIC - 8.5 - 219 BHP 16 valves
78---------------------EURO--4.5 (4,474) 95/79---K JETRONIC - 8.5 - 240 BHP 5,500 RPM 257 LB FT 3,600 RPM 16 valves
79 ------------------- US - -- 4.5 (4,474) 95/79 - K JETRONIC - 8.5 - 219HP 16 valves
79---------------------EURO--4.5 (4,474) 95/79---K JETRONIC - 8.5 - 240 BHP 5,500 RPM 257 LB FT 3,600 RPM 16 valves
80 ------------------- US - -- 4.5 (4,474) 95/79- K JET lambda- 8.5 - 230 BHP 16 valves
80 -------- S -------- EURO--4.7 (4664) 97/79 -- K JETRONIC - 10.0--300 BHP 5500 283 LB FT 4,500 RPM S CAMS 16 valves
81 ------------------- US - -- 4.5 (4,474) 95/79- K JET lambda- 8.5 - 230 BHP 16 valves
81 -------- S -------- EURO--4.7 (4664) 97/79 -- K JETRONIC - 10.0--300 BHP 5500 283 LB FT 4,500 RPM S CAMS 16 valves
82 ------------------- US - -- 4.5 (4,474) 95/79- K JET lambda- 8.5 - 230 BHP 16 valves
82 -------- S -------- EURO--4.7 (4664) 97/79 -- K JETRONIC - 10.0--300 BHP 5500 283 LB FT 4,500 RPM S CAMS 16 valves
83 ---------S--------- US -- -- 4.7 (4664) 97/79 - K JET lambda- 8.5 - 234 BHP 16 valves
83 -------- S -------- EURO--4.7 (4664) 97/79 -- K JETRONIC - 10.0--300 BHP 5500 283 LB FT 4,500 RPM S CAMS 16 valves
84 ---------S--------- US -- -- 4.7 (4664) 97/79 - K JET lambda- 8.5 - 234 BHP 16 valves
84 -------- S2 -------- EURO--4.7 (4664) 97/79 -- LH JETRONIC - 10.0--310 BHP 5900 295 LB FT 4,500 RPM S CAMS 16 valves
85 --S-series 3------- US-----5.0 (4957) 100/79-- LH JETRONIC- ? -288 BHP 5,750 5750 303 LB FT 2,700 RPM 32 VALVES
85 -------- S2 -------- EURO--4.7 (4664) 97/79 -- LH JETRONIC - 10.0--310 BHP 5900 295 LB FT 4,500 RPM S CAMS 16 valves
86 --S-series 3---------- US-----5.0 (4957) 100/79-- LH JETRONIC- ? -288 BHP 5,750 5750 303 LB FT 2,700 RPM 32 VALVES
86 -------- S2 -------- EURO--4.7 (4664) 97/79 -- LH JETRONIC - 10.0--310 BHP 5900 295 LB FT 4,500 RPM S CAMS 16 valves
87 ----- S4 ---ALL MARKETS--5.0 (4957) 100/79--MOTRONIC ---10.0--320 BHP 6000 317 LB FT 3,000 RPM 32 VALVES
88 ----- S4 ---ALL MARKETS--5.0 (4957) 100/79--MOTRONIC ---10.0--320 BHP 6000 317 LB FT 3,000 RPM 32 VALVES
89 ----- S4 ---ALL MARKETS--5.0 (4957) 100/79--MOTRONIC ---10.0--320 BHP 6000 317 LB FT 3,000 RPM 32 VALVES
90 -S4 AUTO-ALL MARKETS--5.0 (4957) 100/79--MOTRONIC ---10.0--320 BHP 6000 317 LB FT 3,000 RPM 32 VALVES
90 ------GT----ALL MARKETS--5.0 (4957) 100/79--MOTRONIC---10.5--330 BHP 6,200 317 LB FT 4,100 RPM 32 VALVES MANUAL TRANS ONLY
91 -S4 AUTO-ALL MARKETS--5.0 (4957) 100/79--MOTRONIC ---10.0--320 BHP 6000 317 LB FT 3,000 RPM 32 VALVES
91 ------GT----ALL MARKETS--5.0 (4957) 100/79--MOTRONIC---10.5--330 BHP 6,200 317 LB FT 4,100 RPM 32 VALVES MANUAL TRANS ONLY
92 -S4 AUTO-ALL MARKETS--5.0 (4957) 100/79--MOTRONIC ---10.0--320 BHP 6000 317 LB FT 3,000 RPM 32 VALVES
92 ------GT----ALL MARKETS--5.0 (4957) 100/79--MOTRONIC---10.5--330 BHP 6,200 317 LB FT 4,100 RPM 32 VALVES MANUAL TRANS ONLY
93 -S4 AUTO-ALL MARKETS--5.0 (4957) 100/79--MOTRONIC ---10.0--320 BHP 6000 317 LB FT 3,000 RPM 32 VALVES
93-------GTS--ALL MARKETS--5.4 (5397) 100/85.9-MOTRONIC--10.4 350 BHP 5700 362 LB FT 4,250 RP, 32 VALVES MANUAL TRANS ONLY
94 -S4 AUTO-ALL MARKETS--5.0 (4957) 100/79--MOTRONIC ---10.0--320 BHP 6000 317 LB FT 3,000 RPM 32 VALVES
94-------GTS--ALL MARKETS--5.4 (5397) 100/85.9-MOTRONIC--10.4 350 BHP 5700 362 LB FT 4,250 RP, 32 VALVES MANUAL TRANS ONLY
95 -S4 AUTO-ALL MARKETS--5.0 (4957) 100/79--MOTRONIC ---10.0--320 BHP 6000 317 LB FT 3,000 RPM 32 VALVES
95-------GTS--ALL MARKETS--5.4 (5397) 100/85.9-MOTRONIC--10.4 350 BHP 5700 362 LB FT 4,250 RP, 32 VALVES MANUAL TRANS ONLY
Old 06-20-2003, 04:54 PM
I´m making this chart because I saw diferent specs in books, sites, magazines.
I`m contacting Pelican to try to insert a 928 tech specs link
I will complement this chart with trans and japan model but the main reason for this chart is the diference of the engine specs and injection type.
I will add the club sport and the se models (previous gt) only euro and uk cars
I still having a lot of doubts, then please help me to correct this chart.
Let me know if you want to add something (engine).
questions
Engine
1.- 78-79 euro vs us why the diference of hp ?
2.- 78-79 us powerband
3.- 85-86 usa model first 32 valves compression and power range ?
4.- diferences between 85-86 (s3) engines with the S4 engines ? apart of injections ?
Injection type
1.- Let me know if this is correct ?
In the bosch fuel injection & engine management of Charles O Probst (great book) says that the 928 injetcions are:
78-79 K ketronic (CIS, continous injection system)
80-84 L- jetronic with lambda. I`m almost sure that this is wrong and this model have K jetronic with lambda
85-86 LH-jetronic (hot wire)
87 Motronic
88-on LH-Motronic
I`m not sure with the 80-84 have parts like electronic injection but still have the fuel reparter (cis) ?
2.- Do the euro s model 80-83 have lambda ?, I believe not
3.- 87 motronic model, is the only year for this injection ? how measure the air ?, with a vane plate like the 944 ?
Models
78-79 928 Euro and us
80-84 928 US
80-83 928 S Euro
84-86 928 S2 Euro
85-86 928 S US (series 3)
87-89 928 S4 all markets
90-95 928 S4 all markets, auto trans only
90-92 928 GT all markets, only manual trans
93-95 928 GTS all markets, manual trans only
Old 06-21-2003, 06:20 AM
Iggy's Avatar
Try this site
You can check this website for the information you need.
Old 06-24-2003, 08:52 AM
That is exactly what I needed !!!!!
thanks
Old 06-24-2003, 09:11 AM
