Timing Marks
Can anyone post Timing alignment on cams and crank and position of distributor please on 1979 Model 928
Old 01-25-2009, 03:19 PM
RicerSchnitzzzle
N2O-SHARK's Avatar
Crank at zero, then you will see a small cut out on each timing gear (With cover off). Line the cut out up with the arrows on the cam cover body. PUt timing belt back on. Then make sure distro is firing at #1. Advance about 1/8 turn and you'll be close. Use a timing gun with vacuum to distro disconeccted and plugged. I think 79 is 32* like the Euros?
Looking for pics of the timing marks for you.
'81 Euro 'S' 928 5-Speed 5.0L Hybrid "Ricerschnitzzzle" Wish list: RollBar, New Helmet and driving lessons
Wishes Done: Body kit, seats, No cat, Headers, X, Afterburners, 3" exhaust, short shifter , 17" TT Rims, 250HP N2O, MSD ignition w/retard+rev limit, MSD billet distributor, Accel Coil. 5.0L block, ported heads, JE race springs + .503 "S+" cams
Old 01-25-2009, 04:36 PM
If you had picture ,I could figure it out better.I don't, know much about these motors
Old 02-01-2009, 12:24 AM
MPDano's Avatar
Try this link, it's how I finally got mine started. My pics are what marks to NOT use, then a few post down is a scan on what that you DO use.
Fuel, spark, and compression, still won't start
My Project from Past to Present
http://www.porsche928forums.com/viewtopic.php?f=9&t=4
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 02-01-2009, 05:31 AM
Radiator tank overflow pic
Thank you , would you have picture of Radiator overflow pipes, I have something missing here
Old 02-04-2009, 06:50 PM
MPDano's Avatar
Is that a right hand drive, everything looks lke it's on the opposite side. That 2nd link I posted has lots of pics when I had my engine out too. I bet you'll find what your looking for there.
Old 02-04-2009, 06:56 PM
MPDano's Avatar
I found some in the thread I was talking about. Here you go:
Old 02-04-2009, 07:04 PM
Network Native
Danglerb's Avatar
Fras, the metal tube ending near the power steering reservoir I "think" has a hose over to the thermostat body. The T half way down the fender is "maybe" for some connection off the rear of the heads?
Old 02-04-2009, 08:31 PM
The hose off the tee goes to a fitting on the back of the thermostat crossover housing between the cylinder heads...
Old 02-05-2009, 04:10 PM
