WAIT! How are you trying to turn the crank over?
![]() Didn't the Craig's List Bandit Mechanic make off with your 27mm socket?!?!?!? ![]() |
I always loan my "generic" brand tools to strangers!
hahaha... You didn't think I was using the "sideways visegrip" method he was employing do you!
Guess what. BY PURE CHANCE I happened to be going through some old pics on my cell phone, and found a few pictures I took of the cam gear locations WAY back when I removed the belt. Well, the gears are EXACTLY where they are supposed to be...
Any other ideas why the engine wont turn? I'm going outside to find out what position the shift lever is in. |
Network Native
Don't apply too much force, something has to be binding. Try and locate the segment of the belt that has increased tension on one side and not the other as you try to turn the motor. If you can't find it that way, I think the belt needs to come off and each part checked for free movement (just not much away from the 45 on the crank).
Ignore what I said about PARK, too late at night for me to think. PARK locks the rear wheels, but torque converter would allow free motion of the motor. |
Was the CL Mechanic able to spin one or both cams by hand?
OK! I'm an idiot. The engine DOES spin! I just wasn't turning hard enough (i'm used to motorcycle engines.....)
Well, I'm going to go put everything back together and put some fresh oil and coolant in it, and give it a whirl!
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD** ![]() |
Spark Plugs OUT! Run Compression checks on all cylinders, post all readings and pics here ASAP! Don't lose momentum ![]()
Ok, I just bought oil, filter, plugs, and compression tool (NAPA) what are the compression readings supposed to be? 32valve.
Automotive Necromancer
caution
Just turn the engine over by hand a few times and every second time check the blasted marks are lining up. IF there is no binding and everything seems OK (crossing fingers) tap the starter and then hand crank a bit to make sure everything is Kosher. Just take compression readings. looking for discrepancies in compression at this point. BTW check the oil and coolant. (duh)
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix. |
LMAO..... I'm glad it wasn't anything serious! ![]()
Imre 1985 928S, 5-Speed, DIY Supercharged http://norcal928.org/DIYSC/index.htm, H-pipe, 12.8sec. |
What did the compression check turn up?
89' 928S4 Meteor Grey auto 86.5' 928S Meteor Grey auto(building engine after TBF) 85.5' 944 NA 5 speed(Now daughters car) 80' 928 Black 5 speed SOLD 79' 928 Guards Red auto SOLD |
Doesn't matter now, he sold the car last weekend.
BB out of the game?
Whaaaattt?
Network Native
One of the guys up here in OC picked it up last Saturday. BB wants to focus on taking apart a nice 79 he bought.
US 83 zinc metallic 5 spd, aka the nice car. Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years. |
It does matter.
I'm the guy that bought it. I've got oil in the coolant. Wondering if he has numbers on the compression check so I can hopefully eliminate a head gasket or cracked block. I'm praying for a ruptured oil cooler.... It smells like motor oil and not tranny fluid. I closed the hood and walked away tonight. I'll dig in tomorrow...
I also saw the S4 when he first bought it, and if it weren't for hard economic times, your S4 would have been in my driveway ![]()
I'll have a compression tester tonight or tomorrow. When I get the results, I will post them.
I'll start a new thread. I got some great advice about testing the radiator, that I will post there. Thanks!
Thread Tools | |
Rate This Thread | |
