Almost done!!! NEED HELP!
Ok guys! I have the water pump on, AND the timing belt on the old engine. (I just need to see what's going on with the old engine, and I KNOW you guys are too!!!)
BUT!!!!!!!!!!! I [I]can't [I] turn the engine over by turning the crank with a socket wrench, even with ALL 8 spark plugs out! This can't be good!!! Dangler??? What do you think? I think the "mechanic" that messed with my cam gears really screwed things up. Does anybody know how to "start over"??? I mean, is there a way to "reset" and put everything at "0" so to say???? please let me know, I'm going to be back on it first thing in the morning. Oh, the spark plug galleys were flooded with oil by the way. Here are pictures of where everything is lined up at. ![]() ![]() ![]()
Doee everything line up when you are at O/T (TDC)?
Imre 1985 928S, 5-Speed, DIY Supercharged http://norcal928.org/DIYSC/index.htm, H-pipe, 12.8sec. |
I cant turn the crank
Did you remove the flywheel locking tool?
Everything seems to be lined up perfectly right now, see pic how the mark on the backing plate lines up with the divots on the gear.
haha... yeah, Dano has it, but that was what I was thinking too, I had to double check even though I knew I gave it back!
What I see is that they are both about 3 teeth too forwards but the crank is at the 45 degree mark. From this point it's difficlut to tell if the marks will lline up when the crank is at TDC.
This is pretty much where they were when I pulled the belt, but one of the gears might be one tooth left or right of the other.
Network Native
Bear in mind I am NOT experienced with 32v motors except to take them apart.
![]() Is the car in park? When you try to turn the motor (usually always clockwise), what seems to be binding? Use a finger to feel the tension on various segments of the belt and that should tell you what doesn't want to move. Try wiggling the different parts, see if something is frozen. If nothing wants to move, I'm thinking the belt needs to come off and then recheck movement of each part. (as long as the crank stays "close" to 45 degrees a little movement should be harmless). Be careful no junk gets down the spark plug holes.
US 83 zinc metallic 5 spd, aka the nice car. Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years. |
Porsche newbie
I count 48 teeth on the camshaft sprocket. So 45 degrees of crank rotation would be 22.5 degrees for the cam. 360 divided by 22.5 is 16. 48 divided by 16 is 3. So the cam should be 3 teeth off. It appears to be set correctly.
I went back to the manual and looked it up. With the crankshaft at the 45 degree mark before Top Dead Center. "Camshafts may be turned without damaging the valves after aligning the 45 deg. mark."
87 928 S4 Exported for Japan Last edited by Niles; 05-08-2009 at 01:10 AM.. |
You were able to turn the crank BEFORE you put the Timing Belt on, correct?
I do see a post saying your marks are on now. Does it turn now? #1 Piston at top? Also, is 4|5 the Correct TDC?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Is the car in neutral or are the rear wheels up? If not, you're trying to move the entire car.
07 Yukon Denali Blue Green Metallic, rolling on 22's 05 Jeep Laredo careened around town by child #1 06 Mustang rolling around town by child #2, in all it's bass thumping glory 88 928 S4 Black 90 928 S4 Linen Grey Metallic Sold 88 924s Black Sold 85.5 944 NA Grey Sold |
This could be off. On the 32V cars you first set crank at T/D and align back notches to notch in back plate. Then turn crank to 45 degs ( this is the only crank position where the cams can be turned WITHOUT interference) then YOU mark the cam gears. Mine were already marked when the PO did the first job....Once aligned turn crank 2 complete rotations to make sure they still align. If the motor will not rotate try removing the plugs.
Is 4|5 the Correct TDC? Ok, found my answer somewhere else. Here are pics of what it should look like.
![]() ![]() Quote:
Since the car is automatic, I should be able to turn it in any gear position correct? I'm not even sure where the shifter is to tell you the truth. Should be park, but it may not have been put back completely. I will check when I go out there.
plugs are removed as of last night.
Someone did the math previously on how many teeth the cam gears should be off the mark at 45 degrees, but can someone confirm he's off (think it was 3 teeth) in the right direction? |
You know, after looking at Dano's picture has me thinking... One of the gears was three teeth past and the other was four. I turned the one gear so it was three teeth past to match up with the other one. Now I'm wondering if I should have turned them both to four since that is how they are in Dano's picture...
Pictures are from 928gt.com, I am betting these are the absolute correct way they should look like.
