cruise control doesnt work
1985 928s 5 speed.
I checked the fuse and its good. The fuse also says is euns the brake lights and they do work. I am guessing there is no on and off switch or dash light saying cruise is engaged. Where should I start?
Thank you Sean
Old 06-12-2009, 09:49 AM
Petie3rd
Mrmerlin's Avatar
do you have the WSM?
If not then that is where to start. you need to get your hands on one.
Could be sensor in the trans the switch on the column the brain or the actuator or the cable
Old 06-12-2009, 10:27 AM
No idea what a wsm is. The speedo and tach work. The odometer just quit.
Old 06-12-2009, 08:20 PM
Petie3rd
Mrmerlin's Avatar
WSM = work shop manual, Jim Morehouse sells a good copy for your puter, with this it will give you information on your that can save you untold millions of dollars that you would otherwise spend figuring out things for your self.
I would strongly recommend that you get the CD version or the printed version
Old 06-12-2009, 09:33 PM
lol... man wsm.... And I am a car guy.... embarassing
Old 06-12-2009, 09:56 PM
Autobahn Garage
Here is a good write up about the repair of the cruise control http://members.rennlist.com/pirtle/zelec_cruise_control.txt
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 06-13-2009, 07:05 AM
