cruise control doesnt work
1985 928s 5 speed.
I checked the fuse and its good. The fuse also says is euns the brake lights and they do work. I am guessing there is no on and off switch or dash light saying cruise is engaged. Where should I start? Thank you Sean |
Petie3rd
do you have the WSM?
If not then that is where to start. you need to get your hands on one. Could be sensor in the trans the switch on the column the brain or the actuator or the cable
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats Last edited by Mrmerlin; 06-12-2009 at 10:30 AM.. |
No idea what a wsm is. The speedo and tach work. The odometer just quit.
Petie3rd
WSM = work shop manual, Jim Morehouse sells a good copy for your puter, with this it will give you information on your that can save you untold millions of dollars that you would otherwise spend figuring out things for your self.
I would strongly recommend that you get the CD version or the printed version
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
lol... man wsm.... And I am a car guy.... embarassing
Autobahn Garage
Here is a good write up about the repair of the cruise control http://members.rennlist.com/pirtle/zelec_cruise_control.txt
T Tanner 76, 911s w/ Webers 76, 914/4 57, Speedster |
