just crashed my s4, now wont start?
hi all, bad snow here in dublin and i have just slid my 928 s4 into a curb, it hit hard and i have not been able to start it, it cut out just as i hit. the fuel pump is not knicking in so i check the fuse, which was blown! so new fuse but no joy, so i check the relay and replaced it with one thats working fine but still no pump. i have not yet checked for power at fuse/relay or pump yet but is there a cut off or something in the s4 for killing the pump in a crash, any ideas why the fuse would have blown? cheers thomas
Wow, sorry to hear that. Glad you walked away from this. Somebody with S4 knowledge will steer you in the right direction.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Personally, I will not drive my 928S in winter, let alone in snow and ice. I have it in my heated garage until Spring. This is 4x4 weather here now in Michigan! Good luck with the car. |
Petie3rd
check the battery connections( battery may not have a hold down).
the starter connections, (Make sure the starter wires are not hitting the pan or sway bar) Inspect the hot post. and wires for broken insulation Remove the fuel pump cover and inspect the wires for a grounding issue (blown fuse)
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
