MPDano's Avatar
Originally Posted by Maleficio View Post
About 12 inches.
I went back and re-read your topic. Why did you get an 18" one made then?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-17-2010, 07:40 PM
Maleficio's Avatar
I just made an estimate, an over-estimate. It's not too long, really.
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 01-09-2011, 02:41 PM
When it comes to wiring and cleaning use this stuff. Nothing better.
DeoxIT D Series and Deoxit Shield S Series
https://caig.com/deoxit-d-series/
Old 05-31-2022, 11:18 PM
harborman's Avatar
Today I will focus on locating and cleaning the other grounds.
Regarding the theory of how electrons travel, I'm sure they do travel through the material, but considering how much of an improvement was made just by cleaning up the outsides of the wires, I'd say electrons prefer traveling on the outside.
Yes, the current flows inside the conductor. However, at high frequency's in the radio spectrum, the higher the frequency will cause the current to flow on the surface of the conductor.
I cleaned all the ground points in my 928 and replaced the ground strap from the battery to frame. It had developed internal resistance. I would suggest replacing that strap.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 06-01-2022, 04:54 AM
stepson's Avatar
Those undercar ground cables are not insulated so that moisture/water will not be held in place, the water will be able to run out, and the ground cable will dry. Just an FYI.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 06-09-2022, 12:28 PM
