84Shark's Avatar
Alternator help
My transmission was rebuilt, and the now shifts perfectly, but the Transmission shop killed two batteries over the last week. The mechanic pointed out that my alternator is bad.
Can I use a gm alternator? Where can a guy get one of those of so.. ?
Old 04-11-2011, 09:16 AM
European Shark
riber.bentsen's Avatar
I don't think it's bad, the 928 alternator just doesn't charge very much sub. 2k revs. If you normally use it as a commuter, you should be fine.
They're all like that
1978 Porsche 928 Euro 5spd. Silver metallic/Black
1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed*
Owning a 928 is risky business - but sometimes you just gotta say "what the fudge".
Old 04-11-2011, 09:20 AM
MPDano's Avatar
Replace it with a Delco. Thread here.
Porsche 928 Forums dot com - View topic - Delco Alternator Replacement
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 04-11-2011, 09:41 AM
928: Serial Enabler
I've got two running, both on 84 USA cars.
88 camaro 105 A optional alternator is the one to select, along with the separately purchased matching pigtail from the parts store shelf.
If you are serious, I've got some good pictures and write up.
The pigtail has 4 possible electrodes. The blue exciter wire is applied to the L terminal. Others are covered over with silicon sealant. Pigtail plugs into the alternator.
Hot wire lug is applied to the + terminal. I might have replaced the hot lug with a slightly smaller heavy brass ring terminal for convenience.
I had to choose a slightly smaller grooved belt, add three washers to the pivot bolt for spacing, and replace the tensioning winder with a single nut/bolt.
I pried the alternator tight, then tightened it down. Have about 25K miles on one, 10K on the other.
84,85,86 928 cars
Old 04-11-2011, 02:09 PM
MPDano's Avatar
Do you have a link to your write up? Also, I just looked at Rock Auto and theres different engines in that year Camaro (V6 or 8). I see 100 A for the V6 Camaro
Old 04-11-2011, 02:42 PM
stepson's Avatar
Why not just have your existing alternator rebuilt? My local alternator shop rebuilds them for me for between 70-90 dollars. New bearings, new diodes, new contacts.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 04-11-2011, 03:09 PM
MPDano's Avatar
Oh gawd, don't get me started on Rebuild Shops. Trust me, do NOT do this. You may have a good one local to you stepson, but most of them are crap. My rebuild experience ending me going to Small Claims Court. Either New or Remanufactured <-- preferably from NAPA.
Old 04-11-2011, 03:16 PM
928: Serial Enabler
Only rebuild I would consider would be Bosch factory rebuild. The 84 alternator is probably a Paris-Rhone, btw.
Looking back, I guess I never did a great write up, but helped folks so many times that it seemed like it.
But there are some segments that will help.
Here's one. Open the link on the first post for a snapshot.
Here's another Delco Alternator Installed - Rennlist Discussion Forums
Here's one with the notched bracket. It you notch the bracket, then you don't need get rid of the tensioner screw arrangement. See picture at post #22. Its on an early car, so he had to use the original pulley (v- pulley swap). The 84, though, has a multi-grooved wide belt and the Camaro delco pulley is the same, so no swap needed.
OB-SOB Alternator upgrade - Page 2 - Rennlist Discussion Forums
84,85,86 928 cars
Old 04-11-2011, 05:35 PM
stepson's Avatar
MPDano,
You could possibly be right about that. I may just have a good shop that knows what they're doing. That being said, I've got an acquaintance who put a Delco alternator on his '81 and has had to replace it every year I've know him. (going for his 5th year and 5th alternator). I dunno what that says necessarily, but I think I'll stick with what Porsche put on there originally.
Old 04-11-2011, 08:44 PM
MPDano's Avatar
Originally Posted by stepson View Post
MPDano,
Good to know as I have always heard good things about the Delco.
Old 04-11-2011, 09:17 PM
84Shark's Avatar
delco cs130...?
I'm not finding this alternator for sale anywhere;
I am checking delco cs 130, and beck/arnley replacement... Does anyone have a link...?
_____________________
Al - Carlsbad, CA
-84 Porsche 928S- Auto "US" Black paint/Black int.
-71 Jaguar XJ6 White paint/tan int.
-03 BMW 525i Light Blue paint/tan int.
Old 04-11-2011, 11:17 PM
The number transfers on up >> 90 / 92 I think also V6 Motor > I see ton's of them In the Salvage yards @ $30 >> Most are not 105 Amp but under that > look for Air Con Application Unit
Old 04-11-2011, 11:37 PM
928: Serial Enabler
First of all, I agree with Stepson.
Use original equipment if you can.
The Delco is a little cheaper in the short run and very accessible.
Depending on the rebuilder, often local, you might have to replace it more often.
Here's a reference to a link:
Go to Rock Auto . com
Type 1988, Chevrolet, Camaro, V6 into the search line.
Choose electrical, then alternator.
They show 85 amp and 100 amp. They are the same alternator wound slightly differently, both delco cs130. They can be wound to higher amperage, too. I've seem them at 100, 105 and 115.
Its the 100 amp unit in this particular company listing.
At Advance Auto or Pep Boys or Kragen or whatever you boys use in Kalifornia, the countergirl will not know what a delco 130 alternator is. They will only know by car. So, for ease, we say "use the 88 camaro" as the communication cue for the counterperson. There are two, and the high output of the two is what you choose. Other cars use the same unit. 88 camaro is easy to remember.
Good luck with it! That black 84 is stunning, still. Be sure to sort out your electrical gremlins.
84,85,86 928 cars
Old 04-12-2011, 04:18 AM
84Shark's Avatar
******** - bad; 928Int good
Ok, I followed the advice, ordered a GM alternator from rock auto. When it arrived we noticed that it was completely frozen. I couldn't even turn the pulley/wheel. That will be the last time I use ********.
I returned the ******** alt, and drove up to 928Int in orange county. Tom at 928Int had the OEM rebuild/replacement, they event swapped the pulley for me.
We installed it last night, now it charges above 14.x at idle... I am good to go.
Now I can drive it back to the transmission shop and have them fix my transmission, although that's another story...
Al - Carlsbad, CA
Old 05-14-2011, 06:56 AM
MPDano's Avatar
Sorry that Delco Mod didn't work out for you, just bad luck I guess. Glad you sorted out your Alternator issue though. What's their plan of attack now with the transmission shop?
Old 05-14-2011, 07:02 AM
84Shark's Avatar
Trans...
Well I haven't paid him a dime, he claimed that no payment is required until it shifts perfectly in all gears with no leaks. I think the guy is honest, he just needs more time, and he needed the charging system working to finish the job.
In terms of the plan, I'll leave that to him. I need to buy a commuter car soon, with the Porsche down and the Benz totaled in junk yard, I am hutrting.
I am looking at 2003 5 series bmw's , I've always liked those cars...
Al - Carlsbad, CA
Old 05-14-2011, 09:07 AM
MPDano's Avatar
...or a 2004 X5
Old 05-14-2011, 10:42 AM
Maleficio's Avatar
Originally Posted by MPDano View Post
...or a 2004 X5
Dude, you are fat.
I lost 25 pounds in three months. You can do it, too.
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 05-14-2011, 10:57 AM
MPDano's Avatar
Originally Posted by Maleficio View Post
Dude, you are fat.
Nah, just big boneded
Was it the Jenny Craig Plan??
Old 05-14-2011, 11:55 AM
Maleficio's Avatar
I kick-started my process by eating testosterone booster pills until my appetite vanished. Fasted for a week, then my body started going crazy, not knowing what to do with the fat stores.
I quit eating junk food, fast food, sugars, energy drinks (can put on 29 pounds per year), started exercising regularly, ......essentially doing everything right, and now my body has become "re-set", and no longer tries to store fat, and my muscle mass is increasing all the time, mostly because of my very simple diet loaded with mainly fish protein.
Old 05-14-2011, 12:02 PM
