Having trouble finding a relay for my electric cooling fan.
I jumped 30 to 87 and the cooling fan runs. I read out the relay and it's bad. Intermittent open/close even without power applied.
The part number on the relay comes up as "fuel pump" when I search it. 92861511301 *********** sells a cheap bridge-style relay for $8. Pelican doesn't offer this relay, but brings up fuel pump relay. The schematics are nearly identical, but not exactly the same. Any suggestions?
1982 Porsche 928, Auto, 4.5 http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945 |
See 82 Relay and Fuse Chart, there are many in your CE that are the same Relay
82 Fuse/Relay Chart 141.951.253.B
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
I would switch it with X for now. It's the same as your Horn Relay. Unless you use your Horn all the time.
Cool.
PCA Certified D.I.
I think there's a relay used in some Caddy's that'll plug right in. I think it's Bosch. Usually found under the hood in 90's =.
928: Serial Enabler
Call Roger. $5 each new.
84,85,86 928 cars |
