disk pads and rotor replacement
Hello everyone:
I need to replace the disc brake pads and rotors on my 1987 928
Does anyone know the torque setting (ft lbs, or nm) for the bolts that hold the disc calipers to the suspension
provenceman
Provenceman
1987 s4 Diamond Blue
Auto Trans
Old 09-13-2011, 02:45 PM
Most people just tighten them down > about 40 to 50 Lbs is fine I expect
To flush out the whole Brake System with New Fluid is a good Idea when you change the Piston settings with New Pads > Your going to crank ( Push them ) them way out from where they where.
Old 09-13-2011, 03:00 PM
153bigblock's Avatar
I make sure the rotors are totally flush with the hub with a non-marring mallet and make them nice and snug with a little anti-seize. Otherwise, I will inevitably be drilling them out upon the next rotor replacement from stripping them because they heat seized to the rotor/hub.
Michael, So Cal
1985 Porsche 928, Black, 5 Speed
1985 Porsche 928, Weissgold Metallic, 5 Speed
1980 Porsche 928, Black on Black, 5 Speed
Old 09-13-2011, 03:13 PM
Pete R's Avatar
brake caliper to steering knuckle/wheel carrier 62ftlbs front and rear
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 09-13-2011, 03:38 PM
Recovering dismantler
neil30076's Avatar
Per the '85-'86 928S, '87-'89 928S4 Tech Specs:
Brake caliper to wheel carrier 85 Nm
Brake disk to wheel hub 10Nm
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
MPDano's Avatar
Are the S4's the same as the S? If so, you'll have a fun time removing the 2 small screws that hod the rotor on. I was able to find my Torque Screwdriver (proper name?) that you hit with a hammer. That was a huge help on some as they did back out with it. One I had to drill out.
You absolutely need to make sure it's flush as this is what will make sure that rotor spins straight. Anti-seize on threads is also a must to make it easier the next time around.
I also just tighten to where it feels right too. I'm kinda old skool on a lot of stuff.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 09-13-2011, 03:43 PM
Thanks everyone for your great advice and tips
Always appreciate the help
provenceman
Provenceman
Auto Trans
Old 09-13-2011, 04:54 PM
Pete R's Avatar
S4's are not the same as the S, but they are held on just like them so everything you wrote applies
Neon SRT4 track car
Old 09-13-2011, 06:18 PM
