disk pads and rotor replacement
Hello everyone:
I need to replace the disc brake pads and rotors on my 1987 928 Does anyone know the torque setting (ft lbs, or nm) for the bolts that hold the disc calipers to the suspension Thanks provenceman
Provenceman 1987 s4 Diamond Blue Auto Trans |
Most people just tighten them down > about 40 to 50 Lbs is fine I expect
To flush out the whole Brake System with New Fluid is a good Idea when you change the Piston settings with New Pads > Your going to crank ( Push them ) them way out from where they where. |
I make sure the rotors are totally flush with the hub with a non-marring mallet and make them nice and snug with a little anti-seize. Otherwise, I will inevitably be drilling them out upon the next rotor replacement from stripping them because they heat seized to the rotor/hub.
Michael, So Cal 1985 Porsche 928, Black, 5 Speed 1985 Porsche 928, Weissgold Metallic, 5 Speed 1980 Porsche 928, Black on Black, 5 Speed |
brake caliper to steering knuckle/wheel carrier 62ftlbs front and rear
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
Recovering dismantler
Per the '85-'86 928S, '87-'89 928S4 Tech Specs:
Brake caliper to wheel carrier 85 Nm Brake disk to wheel hub 10Nm
Neil 2009 Mini Cooper 2004 Mercedes CLK500 2024 Subaru Outback Touring XT 2020 Entegra Coach Last edited by neil30076; 09-13-2011 at 03:41 PM.. |
Are the S4's the same as the S? If so, you'll have a fun time removing the 2 small screws that hod the rotor on. I was able to find my Torque Screwdriver (proper name?) that you hit with a hammer. That was a huge help on some as they did back out with it. One I had to drill out.
You absolutely need to make sure it's flush as this is what will make sure that rotor spins straight. Anti-seize on threads is also a must to make it easier the next time around. I also just tighten to where it feels right too. I'm kinda old skool on a lot of stuff.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD** ![]() |
Thanks everyone for your great advice and tips
Always appreciate the help provenceman
Thread Tools | |
Rate This Thread | |
