GTP
What wire gauge are you using? Any one know the wire equivalent of the flat cable? The round one is longer.
G-Man 1984 928S Black/black 77,000mi 1986 944 NA w/ S2 front valence Black/black 91,000mi 1970 911T 49,000mi SOLD |
928-Electrics Guy
Sorry its NOT a kill switch. Though it could kill some of your electronics if you try to use it that way.
It is a battery isolation switch, but I would not do it that way, keep the wire big (1/0), short ~3" and non-movable (e.g. not on tool panel). This is suitable for maintenance use, battery charging & security. If you want a real racing kill switch - you need to rewire the whole car, and really it needs to be on the outside, or accessible by wire pull from the outside. Alan
1994 928 GTS Black/Black Manual Last edited by Alan in AZ; 02-03-2012 at 08:06 AM.. |
928-Electrics Guy
Alan
1994 928 GTS Black/Black Manual |
Engineer of profanity
I have a fuel pump cutoff switch as well. My car is actually setup on a different hot wire with a switch, relay, and fuse to the fuel pump. The PO said the original wiring to the fuel pump was burned. I checked it and he was right. This is probably the sourch of my draw. Hence the turn off switch. So far the wiring job is pretty solid though I did rewire some of it with wires from another 928. This rear switch is just a test idea. I wouldn't kill this switch while the car is running or anything. It's just to make it easier to turn off the battery for wrenching and battery preservation. That way I don't have to move covers, carpet, tool panel and all.
1970 Porsche 911T Black 1990 Porsche 944 S2 Red on cashmere 1984 Porsche 928S Euro ROW GP white on black Last edited by 924CarreraGTP; 02-03-2012 at 09:04 AM.. |
928-Electrics Guy
I suspect that everybody does...
So my point is - lets call it what is is in case anybody else gets the wrong idea about this - switching the battery out of circuit when the car is running is a VERY VERY BAD idea... Alan
1994 928 GTS Black/Black Manual Last edited by Alan in AZ; 02-03-2012 at 10:33 AM.. |
I also got the battery isolation switch for free. So that might help explain my idea. I would go back and change the original thread name to Battery Isolation Switch but I can't edit that part. So I'll just look stupid.
1970 Porsche 911T Black 1990 Porsche 944 S2 Red on cashmere 1984 Porsche 928S Euro ROW GP white on black Last edited by 924CarreraGTP; 02-03-2012 at 09:13 AM.. |
I guess I'm Old Skool as that's how I have always referenced this part as a Kill Switch. I do see your point Alan.
Here is an interesting description in a Hot Rod Mag: Quote:
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
928-Electrics Guy
The battery switch shown is quite actually adequate for normal duty, I have a similar one installed differently. However if you want the best battery switch money can buy - look for one from Blue Sea Systems: HD-Series Battery Switches - PN - Blue Sea Systems These also come in 2 way changeover and AFD options. Superb quality and sealed for marine use.
In the end how you install it is much more important than what it is. Don't add a new weak link to your cars higest power circuit. Alan
I've done some positively bent things to a 928s electronics and they still work. I've hooked 50 amp chargers to the front jumper station to start a car over 100 times. The Jetronic still works flawlessly. The 928 is a pretty robust old dog. If anything I wouldn't make a habit of using it as a kill switch unless the car is upside down. I'm working on a different ground strap setup. This is just the test for it. I have an original 911 ground strap. It's short and braided. I may use it.
1970 Porsche 911T Black 1990 Porsche 944 S2 Red on cashmere 1984 Porsche 928S Euro ROW GP white on black |
928-Electrics Guy
The HD switch I showed is a simply superb switch - its current rating is 600A continuous, 2750A for 10 sec cranking. There is nothing to worry about with this switch - excepts its cost and size. I have 2 of these - I actually consider them works of art, I don't say that about much electric hardware.
The studs are heavily plated copper and sized for up to 4/0 cable. If you reimplement your switch don't use any wiring on the ground point side - fabricate a copper/brass or aluminum bracket so the switch bolts to the GP directly. Make the bracket sized to ~2/0 AWG. This is not a racing kill switch and would not pass a sanctioning body check. The point is if you are in the car, unconscious and someone needs to kill the car a kill switch should work to stop the car AND disconnect all power. Yours will not stop the car if the engine is running, so won't kill power => useless. Alan See pics for a good implementation strategy: ![]() ![]()
1994 928 GTS Black/Black Manual Last edited by Alan in AZ; 02-06-2012 at 11:31 AM.. |
$62.95 for that little switch on eBay
928-Electrics Guy
Alan
