MPDano's Avatar
Originally Posted by dcrasta View Post
This:
I had a motor that would stop, and I would 'fonzie' it up (hit the door). Sprayed some Deoxit in the brushes and it works great. Also check for corrosion on the connector to the motor (may want to do that first) . Corrosion increases resistance in the circuit, and causes voltage drops.
You do realize that there will be some that will have no idea what "fonzie" means, don't you? Here's a Pic to understand for you young whippersnappers
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 03-13-2012, 01:40 PM
Engineer of profanity
924CarreraGTP's Avatar
So would you go as far as to say that he needs to winkler it up a little bit and then see if it works? If that doesn't work he could try to henry it? As long as he doesn't roger it we'll be okay. Roger: english slang for buggering
1970 Porsche 911T Black
1990 Porsche 944 S2 Red on cashmere
1984 Porsche 928S Euro ROW GP white on black
Old 03-14-2012, 12:33 AM
928 Newbie
dcrasta's Avatar
It was all over once I jumped the Shark..
Old 03-14-2012, 11:07 PM
A.J.
tychain99's Avatar
I have a motor if that ends up being the problem. My window broke and I needed the little plastic disc off the control arm. Mine decayed and fell apart causing the window to fall into the door. I bought a whole assembly, and did not use the motor. The plastic clip is riveted in and the purchase was useless . I had my brother make a replica out of metal, and tack welded it on to my arm, and it works fine.. long story for no reason, but I have a motor collecting dust.
1980 auto- cashmere beige
1984 auto- black on black
Old 03-15-2012, 04:00 PM
