Problem instrument cluster 928 S '81
Hi guys,
I'm from Belgium and i have a problem with my 1981 928 S.
My speedometer works but my odometer doesn't, i've put already an other speedometer, it stayed the same i've also put in another backprint (or how you call it) and it stays the same.
Can anyone help me ?
Greetings
Old 04-09-2012, 10:29 AM
SanDiego928's Avatar
Very common issue with all old 928's I believe. Mine has never worked and someday I will fix.
Here is a link to read ---->> Link
PS: Greetings and Welcome. :-)
Mark
1981 928
Old 04-09-2012, 10:33 AM
MPDano's Avatar
Originally Posted by Dirk Gelaude View Post
Hi guys,
Greetings
More than likely the Odometer Gear. It disintegrates after time. Terrible material used. Here is a link to buy one, but there is also a write up on how to get in there and replace it. If this is the case, when you replaced your Speedometer in the past, you should have seen small broken bits of plastic.
Porsche 928, 944, 944S, 944S2, 944 Turbo Odometer Gear.
[IMG]http://www.*****************.com/v/vspfiles/photos/OG-944L-2T.jpg[/IMG]
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 04-09-2012, 11:08 AM
MPDano's Avatar
Actually found a pdf on the procedure. Excellent pics on it as well.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CDcQFjAA&url=http%3A%2F%2Fwww.odometergears.com%2Fdocumenta tion%2FPorsche_928_Odometer_Gear_Replacement.pdf&ei=5ySDT7jJDMfwrQeT6qjpBQ&usg=AFQjCNE7FeCBijFDCzZAsV8poKy7WKKIhA&sig2=82sf5TUJT0ctVvqHCDtoog
Old 04-09-2012, 11:12 AM
You the man - Dano.....so nice with pics.....
Mark
1981 928
Old 04-09-2012, 11:36 AM
MPDano's Avatar
Great thread. I added the fix to the "Common Fixes" thread as well.
Old 04-09-2012, 01:19 PM
First, thx guys for thinking with me to solve this problem,
Dano, thx for the advice, but i allready checked the odometer gear from both speedometers and they are ok. But now, yesterday i've looked again at the car and kept changing the printplates and speedometers from each other and suddenly the speedometer didn't work anymore at all. Then i examened the wire connections in the trunk, didn't see nothing really wrong with, but wiggled it a bit, tryed again and HOORAY everything worked. Put the dash and everything back together again, and.... it stopped working again grrrr . I'm getting grey hair from this car .
Ok, so i've got a spooky car....
I'm going to check the wiring again.
To be continued....
Thx guys for thinking with me to solve this problem
Old 04-10-2012, 11:06 PM
MPDano's Avatar
To be continued....
Yes, there is this wire bundle, plus there is a sensor mounted on the rear of the Diff. Remove and Clean with a wire brush. This part get's a lot corrosion.
Old 04-11-2012, 05:20 AM
Hi guys,
I think the problem is solved..... the connectors in the back ( in front of the spare tire) were not correctly given contact inside of the plastic where they come together. It all works for now, let's hope it stays that way.
Thanks again to you all for your responses.
Old 04-11-2012, 11:22 AM
Hi guys,
In the back ( in front of the spare wheel ) inside the plastic connectors the pins were giving bad contact. Pushed them a little further in there places and everything works . Hope it stays that way.
Thanks to you all for your time and responses.
By the way, does anybody know how to level the headlights, so they are equal in the front fenders ? The left one is not properly in position (to high) when laying down.
Old 04-11-2012, 11:35 AM
nuts4porsche's Avatar
you should be able to hand turn them up and down-adjust them drivers side knob under hood between headlights dano has a pic of it im sure!
80 US auto
Old 04-11-2012, 12:58 PM
MPDano's Avatar
That just manually brings them up or down. His is just not aligned correctly. I've never had to adjust mine, but i am sure if you look at the assembly, you can figure it out. I do believe off hand that there are some nuts that hold the light assembly on the pole. These you should be able to see right as you open the hood. On the left and right sides of the pole.
Old 04-11-2012, 01:06 PM
Dirk
What are the colors of the wires at the connector you worked on near the spare tire?
THX G-Man
Hi guys,
G-Man
1984 928S Black/black 77,000mi
1986 944 NA w/ S2 front valence Black/black 91,000mi
1970 911T 49,000mi SOLD
Old 04-11-2012, 04:47 PM
Odometer
Ok guys,
I'm back again, the odometer worked about 8 kilometers (5 miles) and went dead again.....And now it's totally finished, the speedometer keeps going, but the odometer doesn't. I don't know how the odometer get's his impuls. Is it from the sensor in the differential (but if that one's gone why does the speedometer work ?), or does he get it from the automatic gear box ? There's two wire's going to the sensor of the diff. and four to the automatic gear box. There's also one (white/brown) going to a kind of magnetic contact to the side of the gear box.
It's very strange that the odometer work for a couple of miles after you work on the car, he also worked a while after working on the dash... (two or three times).
But now it seems totally finished.
@ Wallstreet , i will look again tomorrow what coulors thy have and if i find the time going to start taking pictures of everything and post them so you guys can see what we are talking about.
@ Nuts4porsche, this knob is just for leveling the beam and this is not what i meant, its the whole unit that is higher on the one side.
@Mpdano, I know what you mean and i've tried it, it doesn't help, looks like i'm gonna have to take the fender of to adjust it.. I must tell you the car is totally been resprayed ( not by me, i bought it this way).
But here again i'm going to post pics. On the other hand this is the least of my concerns now....
To be continued.....
Old 04-12-2012, 11:29 AM
MPDano's Avatar
Did you put the front on Ramps and raise the lights, then look underneath. It has to be visible and I don't think you need to remove a Fender to get to all the Assembly Guts.
Old 04-12-2012, 02:26 PM
Kool
AirtekHVAC's Avatar
on the 78, you can easily get to the assembly and mechanism from under the fender...mine does not have a wheel well insert, but looks like there was one there at one time...perhaps a few screws, and then you will have access?
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 04-12-2012, 04:17 PM
MPDano's Avatar
Oh yea, forgot about that Cover. I thought he was talking about the whole fender. Yes, a few screws and that cover comes off. Most cars are missing that cover since they seem to disintegrate
Old 04-12-2012, 04:33 PM
Hi guys,
been working a couple of hours on the car's odometer (again) on saturday and i' think i have two problem's with it. The odometer wasn't working because of the little gear thing missing a few teeth. But the second thing is very strange. When i've put the wole dash together again the odometer kept running ( after running for 15 km's with the car on a jack) till i get home. The other day it didn't work again (grrrr) but started working after a couple of km's. Since then it starts working everytime after a couple of km's when you've stopped the car for a couple of hours. I will leave it for now, because it works and honestly i'm a little bit fed up with this odometer thing. About the headlight adjustment, i will do it later and post some pics too.
Old 04-16-2012, 12:02 PM
Her's the pic of the little gear missing some tooth.
Old 04-16-2012, 12:04 PM
