83 US 928 Guards Red
83 928 o2 sensor help
I have an 83 928, I am in the process of replacing the o2 sensor. finding and replacing on the outside of car seems to be easy, can anyone tell me exactly where the sensor wire is located (plugs in) inside the car? and how to best access this location? thanks.
Old 05-15-2012, 06:28 AM
MPDano's Avatar
It's connected at the bottom of the CE panel. It's located right where the passengers feet would be. Lift the carpet and it will become obvious how to gain access.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-15-2012, 07:12 AM
thanks. this is helpful. anyone have any tips/advise for this replacement?
Old 05-15-2012, 07:49 AM
928 Newbie
dcrasta's Avatar
On my 86 the 02 sensor lives in the V of the Cats. I had to drop the cats at the exhaust manifolds to reach the sensor.
I believe its a 17mm Open end wrench (use some chemicals to break it free (pb-blaster)) and a little antiseize (on the last threads) when installing the new one (none in the sensor itself, just the back half of the threads.)
Old 05-15-2012, 09:31 AM
Thanks. On my 83 the sensor itself is fairly accessible without having to drop the catalytic. My problem is finding exactly where the wire come through into the inside of the car (I know its near the CE board) Do I need to move the CE board to locate this? It would be nice to see a pic posted anywhere of that wire coming through, as well as what it plugs into. I'm kinda surprised this O2 replacement hasn't been covered more thoroughly someplace...
Old 05-15-2012, 09:54 AM
MPDano's Avatar
Seriously? If you look at the CE panel, it will be obvious like I said earlier. It will enter in the tunnel area and a foot of wire to a connector. Are you sure you want a 928 to learn to work on?
Old 05-15-2012, 10:10 AM
Of course I want a 928 to "learn" to work on- why wouldn't I if they're sooo "obvious" and easy like you say. I love my 928 buddy, I just don't want to F-up anything else around the CE panel, and with the unbelievable amount of pictures and forums on every other process, I just thought it odd that no-one has covered this better... thanks again...
Old 05-15-2012, 10:25 AM
MPDano's Avatar
Here are some pics in my $900 Porsche Thread. also, go through it as well as my Euro thread and you'll have enough pics to tear down a 928 and put it back together.
$900 1983 US 928S The latest LEO928S
Old 05-15-2012, 11:08 AM
perfect! just what I was looking for! thanks again.
Old 05-15-2012, 11:19 AM
ok, the wires have all been located, now whats the deal with 2 wire vs 3 wire? the replacement part is 3 wire, the original is 2 wire.....
Old 05-16-2012, 05:58 AM
MPDano's Avatar
I believe 3 wire is a pre-heater. My S came stock with 3 wires IIRC as the pic shows. Mine is an 83 as yours.
Old 05-16-2012, 10:27 AM
Tags
o2 sensor replacement
