Not using an Oxygen sensor
87 S4 auto...
Hey all,,Well after starting a tranny filter change, WYAI bit me..so..after transmission springs new hoses/lines, exhaust hangers, cleaned painted exhaust, and undercarriage, new vac lines and modulator,and a cat bypass...on the road with a great sound...and no leaks!!! But the bypass doesn't have a usable port for the O2 sensor..It has a dummy outlet..as it turned out my old sensors wasnt hooked up to start with. So, what is the disadvantage of no sensor? Also, the power seems to be less at lower rpm..seems a bit dogged.... thnx as always... joihn
Whoa! Interesting .
Formerly from ratslist. AMG E 55..2002. Lotus Esprit SE. 1990 |
without the sensor you are probably using a lot more fuel than you need too.
(Running rich) Last edited by Plexus928; 06-07-2012 at 12:17 AM.. |
Fuel mix will not be right. I would find a place to add the O2. On my X-pipe there is an O2 tap on just one side....which is probably just fine.
1980 AUTO Synergy Green Metallic / Black & Grey ( my son's) 1989 Auto Slate Grey Metallic / Cashmere & Black (mine) 1982 5-speed White / Black sport seats ( brothers ) |
You can buy a bung all over ebay and have it installed at a competent muffler shop. Or if your good at welding, drill the hole yourself and weld the bung in.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
