A/C blowing warm - questions
I went for a drive last week and used the A/C. It cooled quite well, but I did hear a hissing sound - it was coming and going, not constant.
Today, I took the car out, pushed the A/C button, but did not get cool air. When I got back home, I popped the hood and verified that the A/C clutch is not engaging.
Could the variable hissing sound have been an indicator of low refrigerant? I'm pretty sure it's still an R12 system. These days, how difficult is it to get an R12 refill?
Hugo
Present: 1984 928S/Indischrot, 1994 968/Polar Silver
Past: 1979 911SC Targa/Petrol Blue
Old 06-09-2012, 05:54 PM
Kool
AirtekHVAC's Avatar
Near impossible unless you know someone who has some laying around. Most shops don't even have it anymore. Sounds like you sprung a leak. Although hoses and seals are permeable, and can seep refrigerant, the only time the system would be flat would be due to leakage. Might be a good time to convert to 134a
Old 06-09-2012, 06:14 PM
Spin-Master's Avatar
Some shops may still have some R12 yet, but at $70+ a pound, now would be the right time to convert to R134 since it sounds like you probably have other issues besides a simple recharge. And, you can maintain an R134 system yourself for cheap compared to what a shop charges.
Old 06-09-2012, 06:24 PM
the hissing is most likely a leak of the AC system.
when the freon is low, the compressor will not engage.
most likely, the freon is gone.
you should have an AC shop figure out where the leak it and fix that. could be a hose or a component of the AC system. once the leak is fixed, then charge it with R134. R134 will be cheaper and easier to find if you need to recharge in the future.
my ac shop charged $45 for diagnosis. they used a sniffer that pin point the leak.
Old 06-09-2012, 08:51 PM
To be clear, the hissing sound was not a leak. It sounded more like the expansion valve doing it's work.
I have the records for the car dating back to late 80's, and can't find anything related to A/C work, so there's a good chance it is/was still running on the original charge.
I'll do some testing to try to confirm if it's low refrigerant. If yes, I may still pursue the R12 route.
Hugo
Old 06-10-2012, 05:32 PM
19psi's Avatar
R12 isn't in demand and the price isn't that outrageous anymore. Check ebay and craigslist.
If the system is overall tight and only needs a minor repair, stick with R12. 134a won't cool as well unless you change the metering device, it shouldn't be used with your existing oil and it will leak down through non barrier hoses and old style o-rings.
There are also replacements to R12 which work great. Downside is that they are azeotropic blends which shouldn't be topped off.
That said, if the system was working perfect and just stopped all of a sudden, you don't have a small leak. If it did leak out, you'll have an oil mess around the damaged area. Your refrigerant may very well be fine. If so, I'd start with pressure switches and the switch on the evaporator which cycles off the compressor to prevent freezing. Hopefully the problem is under the hood and not with the interior climate controls.
George in Indiana
928 Weissach #153
Cayenne S
Old 06-10-2012, 05:55 PM
stepson's Avatar
The hissing was likely a vacuum leak from one of the actuators. Check for vacuum leaks inside the cabin.
The pressure sensor switch will keep the compressor clutch from activating if there is not enough freon pressure in the system.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 06-10-2012, 07:13 PM
harborman's Avatar
I had mine recharged last year with R12. The shop had it. Cost me $130 or something. That freon fiasco is a joke, a jump to conclusions on the hole in the atmosphere.
Your problem might be vacuum related. Take your air cleaner box out and see if the heater valve is closing.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 06-11-2012, 05:28 AM
JK McDonald's Avatar
Freeze 12 -
Check locally or on the internet for some Freeze 12. It is a blended freon that can be installed right into the older R12 automotive air conditioning systems. Some prefer to go through the R134 conversion process but I've used Freeze 12 for years in lots of cars with complete satisfaction.
The first step is to always inspect your vacuum control circuit, all the high pressure hoses, replace all your line seals, replace the dryer, make sure your A/C clutch is working (a quick test is to jumper +12 Volts to the coil and listen for the click) and then pull a good 29" vacuum on the whole system. Just for good measure, I usually leave the gauges on for an hour or so to make sure the vacuum holds. Usually a couple of pounds of Freeze 12 will keep you cool for years without the expense of the R134 conversion process.
One other check is to make sure your hot water shut off valve has closed when the A/C switch is pressed. Many 928 owners temporarily zip tie the hot water shut off valve (mounted on the firewall - back side of the air cleaner) closed each summer in the hotter locals.
Good Luck, Michael
1984 928S - "Miss Purdy"
1987 911SC - "Frau Helga"
1986 930 - "Well Hung"
1975 911 Targa "Blue"
Old 06-11-2012, 05:33 AM
I'm fairly certain all the vacuum stuff is working properly. I was getting heating in the winter and A/C cooling up to last week. I haven't had a chance to test anything yet other than to confirm the compressor clutch is not engaging. I am not getting warm or hot air when I try to run A/C, it's definitely outside air temperature. I figure if I jump the low pressure switch, I can check if the clutch engages. If it does, then low refrigerant is the likely culprit. I don't have gauges so I can't test it directly.
As for ozone hole, this isn't the right forum and I don't want to inject politics into it at all, but there is very solid science behind the issue of CFC's and ozone depletion. The Wikipedia article Ozone depletion - Wikipedia, the free encyclopedia has a good overview. That is all I will say on that subject.
Hugo
Old 06-11-2012, 07:32 AM
MPDano's Avatar
Leave this stuff up to the Ac Pros. Find a reputable AC Shop near you. The system isn't any different from other cars. Make sure to Evac that R12 legally, it's illegal to go releasing all that R12 into the atmosphere. Plus, you'll feel good not putting your future generations in jeopardy.
Mine was already empty in the Euro so I replaced all the o-rings myself and took it to the AC Shop for them to do their magic. There is a specific amount of Refrigerant (R134) and Oil that is put into your system, don't try and guess on this. I blew up a Compressor doing this, it's not worth it.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 06-11-2012, 07:48 AM
harborman's Avatar
Hugo
Yes, wrong place for this. But the "hole" is almost gone. As for recharge, plenty of R12 still around. But best find the leaks first.
1986 928S
32 valve engine
Old 06-11-2012, 11:19 AM
What's Facebook?
turborat's Avatar
I have used this on well over a dozen R12 German Car AC systems without incident. Fix the leak or determine the "clutch" issue first.
Enviro-Safe Refrigerants
Turborat
"’Cause every once in while, the lion has to show the jackals who he is”
1979 911 SC - 2100 LB track rat
1986.5 928 5-Speed - 36,000 miles
2001 330Ci
Old 06-11-2012, 03:11 PM
1982_928's Avatar
Go out to your car and pop the hood. Find the high or low side charge port on the system, and pull one of the caps off. Press the schrader valve (Its the same thing as whats in a car tire valve stem) and see if there is pressure on it. If there is pressure on it, its not completely empty, which means there isnt a huge hole. It may have already been low, and finally got to the point where the low pressure switch cut it off. If you heard a "hissing" noise, that doesnt sould like an expansion valve.. Thats probably a hole in the system. Just hope is isnt the evaporator..
Ac systems are not that complex. Its much cheaper to buy gauges and a vacuum pump and do it all yourself. Ive been doing it for quite a while. I dont know if you can buy r12 gauges anymore, though.. The hoses on my gauges are going down hill, so ill be looking for some.
You are "supposed" to have a license to buy r12....You can still find it some places. Just pay cash so it doesn't leave a trail. I've heard the Freeze 12 is supposed to be decent, and soon im going to charge my pickup with some of it.
Anyways, if it is empty, i would just go to Freeze 12. R134a and R12's pressures are different, as a result the expansion valve needs to be adjusted, new o rings, but new hoses arent needed for 134. Ive never changed hoses when converting and havent had a leak.
If you go to freeze 12, you dont need to change o rings or adjust anything. If you put anything other than r12 in it, (and you do it yourself) Put Ester oil in it. Its compatible with r134 and r12.
Remember, if you convert, pull a vacuum on it, because r12 and r134 mixed supposedly turns to an acid and eats your system.
As for the hole in the ozone... Complete bull****, R12 had nothing to do with it. Its just government crap. They sure didnt think to check for that hole in the ozone layer 200 years ago, Did they? Sure, theres been "research" on CFC's killing the layer, but there have been just as many or more showing that it had nothing to do with it.
Hope all of that jubberish i just wrote makes sense.. Good luck!
MPDano, What is the temperature coming out of the vents on your car? 134 usually doesnt cool as well without a bit of work.
Jonah Boyd
78 928 5 speed - #111
81 928 5 speed - the "Copper Turd"
81 928 Auto
Old 06-11-2012, 11:13 PM
pjg pjg is offline
pjg's Avatar
Its 20 bucks to take the 609 cert test its an easy online test EPA 609 Open Book Certification
once you pass you can buy r12 on ebay: R-12 FREON, REFRIGERANT, DU-PONT TWO (2) CANS WITH INSTALLATION HOSE. SUPER COLD | eBay
R12 manifold gauges on Amazon: Mastercool 98660 Dual 134A R-12 Aluminum Gauge Set: Amazon.com: Industrial & Scientific
______________________________________________
Paul
85 Euro 5 speed
89 S4 60k
Old 06-12-2012, 02:30 AM
Kool
AirtekHVAC's Avatar
I don't like the blend gases....most have to be liquid charged, which can damage the compressor if not performed properly. I don't chime in too often on AC related stuff...kinda like the computer guys who work on them all day don't touch them when they get home....
I hate the cheapo certification tests, as I feel they really don't teach the average joe anything, just a way to bypass or bend the rules (that said, I am a little hypocritical, as I took the ASE $20 test many moons ago, back when it was $15, but...I was already a certified HVAC tech). I don't oppose any DIY efforts...but I have seen many systems damaged by untrained personnell, and quite a few injuries...don't want to see anyone hurt....
Anyway did not mean to hijack the thread...just be safe messing with this stuff, it is high pressure.
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 06-12-2012, 04:19 AM
Finally had a chance to poke around today. Unscrewed the protective cap on the low side port and pressed the pin for a quarter second and heard the sound of escaping gas.
Next step is to find a shop local to me that would be willing to work to find the leak (if any) and recharge with R12.
Hugo
Old 06-17-2012, 09:54 AM
Network Native
Danglerb's Avatar
I've become very leery of allowing any shop that doesn't know the 928 well to touch it, and I have yet to find a task simple enough an experienced non 928 mechanic can't screw up in a potentially very expensive way.
Old 06-17-2012, 12:07 PM
words of wisdom to live by! 100% correct
1956 Intermeccanica 356 Speedster (sold),1957 Intermeccanica 356 Speedster (sold),,1985.5 Porsche 944 (sold),1955 Thunder Ranch 550 Spyder (sold), 1955 Outlaw 356 Speedster (currently in build out), 1984 Porsche 928S (White), 1984 Porsche 928S (Red)
Old 06-17-2012, 04:31 PM
So I finally got a chance to have the car looked at by a trusted shop. They pulled a vacuum and let it sit for an hour. After confirming there were no leaks they recharged the system with R12.
Total cost was $100 for shop time, refrigerant recovery, etc plus $75 for R12 that I purchased using eBay.
Hugo
Old 08-16-2012, 02:38 PM
