1980 Porsche 928
Best way to check timing in a 1980?
What is the best way to check the timing without taking too much apart?
Old 08-19-2013, 05:14 PM
1982 928 us
belt itself for too loose/tight. walking off center cam wheel groves.. inspection. pop the pass side cover/ center of cover long 8mm? bolt, finesse the rad hose, dip stick , maybe remove the air tube on top?.
tightens and loosen by the tension (which should be full of oil) down where the first cover meets middle cover.
you need the kempf tool (exc instructs with it) to perfect it. but if its way loose or way tight at least able to catch a problem before it becomes painful without the tool.
timing marks on vibration damper what do urs say. standing in front and reading , 0/0 to....
timing cam wheels marks are on wheels back side.
distributor has markings/notches where are urs?
1982 Porsche 928 us
Old 08-20-2013, 12:09 PM
SharkHead
JhwShark's Avatar
Timing light?
Use a timing light. Plug it in ground and +, then place the induction lead on number 1 plug wire. Start the car shoot the light at the damper and adjust as necessary at the dizzy.
Is this a new procedure for you?
'79 928, 85k Opal Metallic
'99 BMW 540i, 97k Titanium
'72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga
Old 08-20-2013, 12:42 PM
1980 Porsche 928
Yes it is a new procedure for me. All I've ever done was replace the belt on my bmw and it i just lined up the marks. But that was with most of the engine apart.
Old 08-20-2013, 03:04 PM
Maleficio's Avatar
Be sure and pull the vacuum advance hose from your distributor. Cap the hose (vacuum leak) until you're finished.
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 08-21-2013, 05:12 AM
MPDano's Avatar
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 08-21-2013, 05:19 AM
1980 Porsche 928
Is there anyway you can upload those differently so I can read them a little better
Old 08-21-2013, 04:59 PM
SharkHead
JhwShark's Avatar
Looks great in Firefox browser...
Old 08-22-2013, 09:56 AM
