GAFB
Am very glad I replaced the cam seals and valve gaskets - they were all completely used up. Good writeup for S3 intake refresh?
Several BMWs |
http://forums.rennlist.com/rennforums/928-forum/663881-just-peachy-ob-project.html How long have you owned the 86.5 ? T Last edited by 77tony; 01-05-2014 at 10:31 PM.. |
Live in TX now, but am originally from CT. I really do miss the sarcasm and quick wit you are displaying, keep it up ! T
GAFB
Several BMWs |
T
Not sure on the 32v's but on the 16v's it's a pretty major undertaking if this is done "in" the car and not engine "out" of the car. IMHO, you would know if it's leaking before cleaning it all up. Although, removing the valve covers afford the perfect time to get them cleaned up and powdercoated
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
GAFB
Several BMWs |
928-Electrics Guy
Alan
1994 928 GTS Black/Black Manual |
Gorgeous engine!
If you are talking about the upper air filter cover, 928Intl did not have it used, but Roger had it new. It was pricey.
Scott '86.5 928S (Guards Red/Black/5 speed/Stock tensioner) California car '87 928S4 (Grand Prix White/Black/5 speed/PorKensioner) Daily driver '99 996 (Black/Grey/6 speed) Wife's car '12 Honda Civic Si (Black/Black/6 speed) Wife's daily driver |
Kool
Looks great, good progress....
Don't you people ever work? Dang, I can barely find a 1/2 hour to go to the shop, even on the weekend...I'm jealous. Keep the pics coming!
Ron 1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project 1982 5sp resto project, 1985 Auto S3 1984 Parts car (the fire car) 1987 s4 (parts, or maybe project) (Yes, I now have 4 project Sharks) |
It seems that your replacements will be fine. IIRC my replacements from Roger were like that as well. Someone with more expertise should chime in.
I would use Optimol TA on the bolts. Did you replace the short hose from the heater valve to the block? I would- easy to do now, hard to do later, very inexpensive. Changing the heater valve, while you are there, is a good idea too. Cheap. You might want to check the crank position sensor, while you are there. The bolt holding it in looks ratty. Who knows what is happening in there. Also, some of your injector wires look like they've had electrical tape wrapped around them. Maybe time to use self-fusing tape. You don't want any foreign matter getting in there. Ditto for the Ground Point IX wire that you've shown. Needs to be protected.
Petie3rd
What Scott said install anew heater control valve and a short hose these are the weak parts of the cooling system
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
928: Serial Enabler
The 86.5 models had the same organ pipe intake as 85/6 cars, never the 87 "compact" manifold. The main similarities with the later 87 car are regarding suspension parts and brakes in the front, and the frontmost suspension mounts in the rear. There are other minor differences, those are the main ones. I have 86 and 86.5 cars side by side in the garage for reference if you run into anymore headscratchers on where the differences lie. The protruding rear jack points are the only visual clue, a dead giveaway. Shop a bit for your parts, there are some good options out there right now.
84,85,86 928 cars Last edited by Landseer; 01-26-2014 at 03:15 AM.. |
Yes, it is called Optimol or Optimoly.
Where to buy it? Ummm, try Pelican. They stock it. Yes, it is an aluminum anti-seize. It is "special." Better than other anti-seizes. (This is coming from the experts, like Greg Brown.) I bought a cheap paint brush so that I could apply the anti-seize to bolts with the brush.
Antsmands
Nice work, what di you use to get it soooooooooo shiny?
1983S 5 Speed / Platinum Metallic / Dark Brown Interior / GE NightHawk LED Headlights / Super Bright LED / Flex-a-lite Cooling Fan / Dragon Gauges / Custom Auto Sounds Spare Tire Sub Woofer / H3R HalGuard Fire Bottle |
Kool
Purdy!!!
80 928
