dtw dtw is offline
GAFB
Originally Posted by desertspirit View Post
I am contemplating removing those valve covers, replacing the gaskets while I am there, and paint everything. Any suggestions on paint?
Thank you.
1986 928 Automatic
Here's my intake refresh thread. I powder-coated my valve covers, intake manifolds, plenums, and strut bar. All the steel hardware, brackets, etc. I had replated in yellow cad.
Am very glad I replaced the cam seals and valve gaskets - they were all completely used up.
Good writeup for S3 intake refresh?
Several BMWs
Old 01-05-2014, 08:54 PM
77tony's Avatar
ok....hold your breath......
Carpeting is gone....original owner ripped it out after he had put in an after market radio that shorted and smoked some wires, burning the carpet.
1986 928 Automatic
Really does not look so bad. Rob Budd has nice carpet kits, etc for your car: Porsche Interior Restoration Leather Craftsman Classic 9 Leather Always easier to start with the carpet pulled, it probabaly needed replacing anyways. This is what I started with. 79 Mocha Brown 5spd, no rub strips or sunroof. T
Old 01-05-2014, 09:01 PM
77tony's Avatar
"Not to bad, This is what I started with:"
Oh wow......where did you find a front cap?
Frame rails were twisted up pretty good so bought an 80 roller. More here:
http://forums.rennlist.com/rennforums/928-forum/663881-just-peachy-ob-project.html
How long have you owned the 86.5 ? T
Old 01-05-2014, 09:12 PM
77tony's Avatar
It sat for five years while previous owner was looking for time to work on it. One day I stopped and offered to take it off his hands and he was primed to deal. I purchased it 3 months ago, unaware if it would even run.
I dropped the tank, cleaned it, checked all fuses and all looked good. Then purchased a fuel pump and filter, put a gallon of premium in and it started right up. Once I knew it would run, I started the work on timing belt and water pump and top end refresh, fuel hoses, vacuum hoses, etc.
Do you think I should pull the valve covers off and change gaskets? It has 68k miles.
1986 928 Automatic
Sounds like your on the right path. Be sure to buy a NEW laso plastic impeller water pump, gates timing belt, porkentenisoner, and porklamp for your automatic. If the valve covers are not weeping, I would hold off on that when your ready to do a top-end refresh a little down the road. Also, do a thourough inspection of those fuel line hoses. Prioritize and get the important stuff done first.02 T
Old 01-06-2014, 06:42 AM
77tony's Avatar
Thank you, Tony.
I am doing the timing belt and new water pump now, as well as seals.
I have the top end all the way down to the valley, intake off, throttle body off, etc. It is difficult to tell if the valve cover gaskets are leaking, or weeping because of the crud on the motor. Now that I cleaned everything up, I could button it back up and run it to see if valve covers are leaking, er....weeping.
BTW, why are you befriending me? Why have you not joined the league of criticizers here who have only offered to poke at me, to which I could not resist replying accordingly? Now perhaps they feel I am arrogant, and a smart mouth, but not themselves.
Thanks again for sharing.
1986 928 Automatic
I went through the same criticism when I started to modified the interior of a 94 GTS a few years back. All hell broke loose on that one: Form & Function. Interior mods 94 928 GTS - Rennlist Discussion Forums
Live in TX now, but am originally from CT. I really do miss the sarcasm and quick wit you are displaying, keep it up ! T
Old 01-06-2014, 07:18 AM
dtw dtw is offline
GAFB
He's doing the top end refresh now - look at the pics, the valve covers are exposed. I'd do them now regardless of mileage - at 27 years, they're baked. Mine were with only about 10K more miles on the clock than his.
Several BMWs
Old 01-06-2014, 07:25 AM
77tony's Avatar
Correct, replace the valve covers WYIT. I forgot he was doing a top end refresh. I am going to go hide now T
Old 01-06-2014, 07:31 AM
MPDano's Avatar
Not sure on the 32v's but on the 16v's it's a pretty major undertaking if this is done "in" the car and not engine "out" of the car. IMHO, you would know if it's leaking before cleaning it all up. Although, removing the valve covers afford the perfect time to get them cleaned up and powdercoated
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 01-06-2014, 07:55 AM
dtw dtw is offline
GAFB
It wasn't any big deal on the 32V, doing the valve covers that is. The cam seals on the other hand, definitely required some finesse. Before installation of the new cam seals, lots of cleaning was required to get out all the old bits of the rubber seals. On the rear cam seals, there's just zero visibility. Most of it I was able to get out by 'feel' using some picks and scotch-brite pads. I could snake a mirror and flashlight in to check my work. A lift can come in handy here, because you can actually get some decent line of sight and access from underneath the car, too. I ended up not bothering to lift the car that high, though, I managed to get it all done from up top.
Several BMWs
Old 01-06-2014, 08:44 AM
928-Electrics Guy
Alan in AZ's Avatar
So after the vehicle fell and crushed my head, and they found me a week later and dragged me from under the vehicle, the doctor told me I needed a new head, and of course a new brain to go with it. I told him that I wanted the best parts used in his overhaul.
So with a new head and new brain, I have some new pics to share with you. Perhaps this post too will be distasteful to some, but hey, what can I say? Go have a nice day and do not drink.
BTW, if the pics are not clear, those are 6 TON jack stands from Harbor Freight that someone suggested. The jack is a 3 ton Craftsman, and works quite well. I am pleased with my new configuration, and my new head.
The doctor also suggested I wear a helmet when I ride.....
1986 928 Automatic
You have a good sense of humor! - You'll fit right in...
Alan
1994 928 GTS Black/Black Manual
Old 01-06-2014, 10:38 AM
syoo8's Avatar
928 110 230 02 - Anyone have one of these for my project?
Gorgeous engine!
If you are talking about the upper air filter cover, 928Intl did not have it used, but Roger had it new. It was pricey.
Scott
'86.5 928S (Guards Red/Black/5 speed/Stock tensioner) California car
'87 928S4 (Grand Prix White/Black/5 speed/PorKensioner) Daily driver
'99 996 (Black/Grey/6 speed) Wife's car
'12 Honda Civic Si (Black/Black/6 speed) Wife's daily driver
Old 01-22-2014, 11:39 AM
Kool
AirtekHVAC's Avatar
Looks great, good progress....
Don't you people ever work? Dang, I can barely find a 1/2 hour to go to the shop, even on the weekend...I'm jealous.
Keep the pics coming!
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 01-22-2014, 07:13 PM
syoo8's Avatar
It seems that your replacements will be fine. IIRC my replacements from Roger were like that as well. Someone with more expertise should chime in.
I would use Optimol TA on the bolts.
Did you replace the short hose from the heater valve to the block? I would- easy to do now, hard to do later, very inexpensive. Changing the heater valve, while you are there, is a good idea too. Cheap.
You might want to check the crank position sensor, while you are there. The bolt holding it in looks ratty. Who knows what is happening in there.
Also, some of your injector wires look like they've had electrical tape wrapped around them. Maybe time to use self-fusing tape. You don't want any foreign matter getting in there. Ditto for the Ground Point IX wire that you've shown. Needs to be protected.
Scott
Old 01-25-2014, 07:09 PM
syoo8's Avatar
Great. Thanks.
So I put a vacuum to the heater valve and it does not leak. The hose is the original. I was thinking of replacing the sensor while I was there. As for all the wires, each of the connectors are wrapped in a plastic bag and then sealed wth the electrical tape. I did then when I began cleaning to keep moisture out of connectors.
I am not in any way disputing that the heater valve etc. are functional right now. Its just that while you are in there, you might as well change all of those items before they become a problem.
Scott
Old 01-25-2014, 08:16 PM
Petie3rd
Mrmerlin's Avatar
What Scott said install anew heater control valve and a short hose these are the weak parts of the cooling system
Old 01-25-2014, 10:28 PM
928: Serial Enabler
The vehicle on the jack stands, I am told by 928Motorsports, based on the engine pics I shared with them, is, in their words, "a true 1986 928," whatever that means.
"I only need to know if your 928 is a true 1986 model (with pipe organ manifold) or the 1986.5 model with the compact manifold like a 1987-1995."
Based on the pic I have included, this vehicle is a "true 1986 model" and not a 1986.5..
1986 928 Automatic
Sorry for delayed response, you've obviously already confirmed that you have a beautiful 86.5 by checking VIN number, last 4 digits being >0999
The 86.5 models had the same organ pipe intake as 85/6 cars, never the 87 "compact" manifold. The main similarities with the later 87 car are regarding suspension parts and brakes in the front, and the frontmost suspension mounts in the rear. There are other minor differences, those are the main ones. I have 86 and 86.5 cars side by side in the garage for reference if you run into anymore headscratchers on where the differences lie. The protruding rear jack points are the only visual clue, a dead giveaway.
Shop a bit for your parts, there are some good options out there right now.
84,85,86 928 cars
Old 01-26-2014, 02:12 AM
syoo8's Avatar
Yes, it is called Optimol or Optimoly.
Where to buy it? Ummm, try Pelican. They stock it.
Yes, it is an aluminum anti-seize. It is "special." Better than other anti-seizes. (This is coming from the experts, like Greg Brown.) I bought a cheap paint brush so that I could apply the anti-seize to bolts with the brush.
Scott
Old 01-26-2014, 09:14 AM
Antsmands
antsmands's Avatar
Nice work, what di you use to get it soooooooooo shiny?
1983S 5 Speed / Platinum Metallic / Dark Brown Interior / GE NightHawk LED Headlights / Super Bright LED / Flex-a-lite Cooling Fan / Dragon Gauges / Custom Auto Sounds Spare Tire Sub Woofer / H3R HalGuard Fire Bottle
Old 01-31-2014, 07:31 AM
Kool
AirtekHVAC's Avatar
Purdy!!!
Ron
Old 01-31-2014, 04:22 PM
80 928
Don't mind Mike, he is from the 70's era and lots of acid. Come to think of it, I see him too
Old guys rule! Dr. Porsche (Ferry) was in his early 50's when the 928 was conceived.
Old 01-31-2014, 06:14 PM
