Jagawar
Newbe with a 928S
Well folks it was a trip. but she runs.. last time it ran was 8 yrs ago. Found the Crank sensor was bad and replaced it. (Whew what a job for someone with big hands) also replaced the fuel pump,fuel filter and fuel gauge sender, New fuel lines and New battery, flushed out the tank, I chked the fuses found not only fuel pump fuse blown but the whole relay was missing as well, someone had just jumped it out. stillhas some quirks to iron out the temp gauge and the fuel gauges are not working and the oil gauge is pegged when running I don't know if that is normal?
Network Native
Oil pressure until hot is usually pegged at idle. Maybe shows pegged all the time if connections are reversed.
My 84's oil pressure gauge is pegged after starting, too. It gravitates to a reasonable reading when warm. Congratulation, on getting it running.
Brian. |
Jagawar
HELP Not outa woods yet
Here is what I have. Changed out the spark plugs 2 hrs Hard work with Big hands ) Still Car will not start unless fuel pump relay jumped . I have no temp gauge and no fuel gauge.. I cked all the fuses cked OK I am praying it is not the ECU buggered.. Anyone have a German Virgin I can Sacrifice? Please Help
Kool
Hey buddy, sounds like you have made some progress since we spoke last. It is possible that the ignition switch might be your culprit....they are a weak link in the system. I just replaced mine recently. Also make sure you have the correct relay. I'm trying to wrap up a couple projects at home, and then my life will return to a little normalcy, I should be able to help you, but you will probably have her going by then....
Ron 1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project 1982 5sp resto project, 1985 Auto S3 1984 Parts car (the fire car) 1987 s4 (parts, or maybe project) (Yes, I now have 4 project Sharks) |
Jagawar
latest update
Becoming a Saga.. I am almost positive I have a Brain dead car. I think the LH computer module has done "Given up the ghost" Engine will not rev above 3k no temp gauge reading no fuel gauge reading, will not run unless pump relay jumped out. tested all the relays all have power.. switch with Known working relay same thing so It looks like I will open my checkbook once again.. I have seen them used for as little as 250.00 and as high as 1k .Doe;s anyone know how much it would cost to rebuild mine? any help is appreciated..
Petie3rd
what year is your car?
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Jagawar
my 928
My car is an 85 No I never hooked up Batt in rev polarity.. My orig question was why my car had two Neg connections for the batt . the later proved to be some sort of batt disconnect. Apparently my car had either multiple prob to start with or caused by someone disconnecting electronics without dis batt. whatever the reason I had No spark and no fuel pump. I changed out the pump (first one was defective) then the sending unit totally corroded, some one had tried in vain to start car and burned up the starter so that was changed. the Batt was Missing when I purchased it replaced with new batt. finally got it running with jumped out fuel pump relay, engine will not spin up past 3k I have No temp gauge or fuel gauge readings while running, Now I think the LH computer is bad. I am tring to find out if it pays to buy a used computer or have mine rebuilt. I found some on E bait. pricing from 250. to 1k
Thanks for the clarification. Must have read your other post wrong, anyway, when you probe around in the terminals for the fuel pump relay with a testlight...what do you come up with? I do not have a wiring diagram for a 928, but I would assume there are a couple hot wires and one running to the pump...and then one that is the ground circuit for the relay (which is probably controlled by the computer). If it is an issue of having no ground circuit when needed, I'd say look into the computer.
As far as getting the computer rebuilt...I'm not sure who would be able to do that. You sure seem to have a boatload of electrical issues, not sure if all of them could be computer related. Good luck, whichever way you go with the computer. Wish I could be of more help, but without laying my handson it...it's just darn difficult figuring these electrical problems out. Brian. |
Jagawar
Thanks Have a Great Holiday.. I am going to go for a computer all the symptoms seem to fit
Jagawar,
Are there any 928 owners in your area? Find someone in your area with an 85-86.5 and ask if they will try your computer in their car. If it starts and runs fine, you will know it's not your computer, but instead something else. Do not try their computer in your car since it could muck up their computer. John Speake can rebuild your computer (JDSPorsche.com) or Rich at info@electronikrepair.com Do not use Specialized Repair in Florida. Bad mojo experiences there.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) Last edited by stepson; 04-05-2015 at 10:56 AM.. |
Jagawar
928 saga continues
Well I bit the bullet and bought a used module, Doe's anyone buy Cores? I just hope I am right and this car finally get back on the road. Getting ready to touch up the paint and redo some interior work.. Smells like dead gas inside.. Whew..
Network Native
LH 2.2 rarely fails, as some have said if you some thing wrong in your car wiring etc. any replacement brain you plug in could insta poof. Test your brain in another car or send it out for testing.
Jagawar
928 prob starting
Well I changed out the computer and bought a new relay for the fuel pump.. No start still the same problem so it is back to square one ,, Need some help here
Jagawar
Found some interesting threads on factory alarms system I am thinking that maybe the culprit, Can anyone tell me or post a pix of how to disable the alarm? desperate to find the problem
