curtisr
Adding chin spoiler -- need help
Hi everyone,
Sacrilegious or not I wish to add a chin spoiler to my '82. This, of course, requires some hole drilling. Hoping someone might be able to help me out by either pointing me in the right direction or providing me with a template for drilling the fender. This is what the spoiler looks like (as if you didn't know): ![]() Thanks!
1977 924 Guards Red (parted and sold) 1987 924s Alpine White (sold) 1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold) 1987 924s Garnet Red (currently becoming Lowencash II) 1982 928 Silver (sold) ![]() |
I didn't mine by fitting it up and marking it, no template. I seems to remember have to do some cutting of the front bumper where the brake ducting goes too.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
Just send your spoiler to me. I'll install it on the Stepson and take pictures for you as I install it. When you see what a PITA it is, you'll rethink installing one on your car. Plus, without a front spoiler, you won't grit your teeth every time you accidently pull too far over a bumper stop and your front spoiler drags coming off of it.
Just trying to look out for you. ![]()
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
curtisr
curtisr
And that's why I will be installing skid plates at the same time. |
Kyle C
Do you have the corresponding upper halves of the brake duct opening?
The other problem with adding a front spoiler to a non-S car is that you can't install the actual brake ducts without also swapping out the front fender support brackets on either side, under/behind the headlights. They are a different shape. You will also need to modify the wheel well covers behind the headlights so the brake ducts have somewhere to exit. So unless you go all the way, you aren't really getting the full benefit.
1974 911 1978 928 5spd hillclimb special 1984 928S 5spd, 1986.5 928S auto 1983 944, 1984 944 track car 1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S |
curtisr
![]() Thanks everyone.
Petie3rd
I borrowed a front PU cover that had the cutouts,
made a template then went to my PU and cut them with a dremel.
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
curtisr
Damn. Is a PU cover a bra?
Who knows. The 928 community is the only one I know that has so many initialisms that a key should be made and put into a sticky atop of every forum.
It's even doubling up...is TBF a Timing Belt Failure or a Thrust Bearing Failure? ![]()
George in Indiana 928 Weissach #153 Cayenne S |
curtisr
rotflmao!!!
Network Native
PU polyurethane the bumper cover, not a bra.
Kyle C
I think the workshop manual has measurements for where to cut out the bumper cover to fit the upper half of the brake duct, in case you can't get your hands on a bumper cover that already has one.
I did mine on my 81 Euro without a template. Pretty much just put the spoiler next to the body and you can see where the holes need to be made. I never got the ducts so I never made those cuts, that can be done in the future. Make sure to heat that cover before you install it, you'll see why when you try and fit the corners on.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD** ![]() |
Thread Tools | |
Rate This Thread | |
