Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
soxnail's Avatar
Originally Posted by nize View Post
another issue contributing to inaccurate control of the wastegate is that the factory wastegate is a single port. converting to a dual-port wastegate improves control.
Agreed..I am trying to do this with the existing WG. Hence the new control and PWM method.
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 09-15-2020, 08:56 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #141 (permalink)
Originally Posted by soxnail View Post
Knock retard will happen at the same place. The retard for high boost will shift by 3 psi.
Sox
I don't know what that means but what I'm saying is that the ign might need to be more retarded at this higher boost level for the same RPM vs WOT to reduce the chance of knock occurring.
Mike G.
Old 09-15-2020, 08:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #142 (permalink)
Super Moderator
nize's Avatar
sox, i have heard and read many have tried to control the factory single-port wastegate at higher boost levels and have either given up or converted to a dual-port wastegate. i believe the factory wastegate is mechanically incapable of providing the type of fine control you're seeking, regardless of how quickly/accurately you can control the cycle valve.
the solution for me was to go with a dual-port wastegate and an aftermarket solenoid (more accurate/faster than the factory CV) to control boost better.
i hope you succeed but hate to see you waste your time.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 09-16-2020, 08:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #143 (permalink)
soxnail's Avatar
Mike G.
I think I understand what you are asking...The ignition retard vs boost and throttle position will change. It will move 3 psi higher, or pressure related retard will happen latter. I don't know if this is enough to cause knock that the knock sensor driven retard will not be able to overcome. Will monitor and report.
Sox
Old 09-16-2020, 08:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #144 (permalink)
soxnail's Avatar
I am using a new PWM controllable solenoid instead of the factory CV, see my post in KLR part 2. As to the WG being unsuitable for more precise control, I don't see why a pressure/spring combination could not achieve better control. Will find out....being retired has it's advantages
Sox
Old 09-16-2020, 08:22 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #145 (permalink)
Stolen form another site
Mike G.
Old 09-16-2020, 09:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #146 (permalink)
Super Moderator
nize's Avatar
lindsey is a great knowledgeable guy with great tech articles, a lot are geared towards selling more products and providing product-specific information. as such, he only mentions in passing the dual-port dual-solenoid solution which provides the best boost control. all three examples show what's known as a two or three-port boost controller and leaves out the critical fourth (and best) configuration which uses a four-port boost controller that takes advantage of a dual-port wastegate. a manual boost controller can not operate as a 4-port controller because it requires constant variable on-the-fly adjustments, so you must get an electronic boost controller to take advantage of a dual-port wastegate.
honestly if anyone is going to use one of those three examples (with a manual boost controller!) they are wasting money buying a dual-port wastegate.
more details here:
https://dsportmag.com/the-tech/education/science-boost-part-1-solenoids/5/
and here is an example that takes advantage of a dual-port wg:
https://tier1motorsports.com/collections/mac-control-solenoids/products/mac-4-port-boost-control-solenoid-valve-for-dual-port-wastegate-46a-aa1-jdba-1ba
edit: a quick search on lindsey doesn't turn up any electronic boost controller so it looks like they only sell manual controllers, which explains why they only show the three boost control configuration examples and ignore the fourth.
Old 09-17-2020, 08:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #147 (permalink)
Super Moderator
nize's Avatar
here is the fourth and best configuration to control boost. this configuration also allows you to use lower spring pressure so if the controller fails it will default to practically zero boost, providing an additional failsafe against damage.
note the 951 factory cripple mode still gives some boost because it's a single-port and relies on higher spring pressure. increasing the factory spring pressure increases cripple mode boost and bypasses the failsafe.
Old 09-17-2020, 08:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #148 (permalink)
soxnail's Avatar
Nize the 4 port you have posted above seems to be a on/off system...I am looking for proportional control in my solenoid.
if that is a proportional control solenoid can you post a part number ?
Thanks Sox
Ignore Nize..should have followed the links above.
Sox
Old 09-17-2020, 10:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #149 (permalink)
I think its one of these guys
https://www.ebay.com/itm/NEW-MAC-4-PORT-BOOST-CONTROL-SOLENOID-VALVE-SENSOR-turbosmart-haltech-aem-apexi-/322993893903
Mike G.
Old 09-17-2020, 03:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #150 (permalink)
soxnail's Avatar
Run with new KLR control system....no tweaking yet. WG is still orignal, no CV.
Sox
Old 09-17-2020, 03:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #151 (permalink)
soxnail's Avatar
Pic of the gauges
Sox
Old 09-17-2020, 03:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #152 (permalink)
Super Moderator
nize's Avatar
Thanks Sox
Sox
just to clarify, the solenoid is on/off but cycles between on/off quickly, and controlling the cycle rate/pulse is how you control boost proportionally. this is the advantage over a manual boost controller.
trivia: the 951 factory cycle valve is called a cycle valve because that's exactly what it does.
Old 09-17-2020, 05:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #153 (permalink)
soxnail's Avatar
Thanks Mike.
Sox
Old 09-18-2020, 08:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #154 (permalink)
soxnail's Avatar
Nize, Mike et all would y'all go and look at my post in the KLR part2 and opine?
SOx
Old 09-18-2020, 01:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #155 (permalink)
soxnail's Avatar
So after doing the characterization of the stock WG and it's control, next was to to do a dual port with a 4 way solenoid control valve.
I have a Tial I am playing with but decided to see if a stock WG could be modified to become a 2 port WG. Much easier to install and no modification/fabrication to the exhaust system.
Short answer is not really....
First I welded the 4 vent holes in the stock WG. Then I put a crush washer to prevent leaks from the top chamber when it is reverse pressurized. Finally I put a 1/8 inch npt 18 barb into the side to introduce air into the bottom part of the WG to hold it closed against the exhaust pressure.
See pics.
The copper crush washer did not work, it leaked as it was not large enough.
Th aluminum crush washer worked to seal the chamber, and it held pressure in both chambers.
Barb installed, notice the welds for the vent holes.
So here is the problem, the piston that moves up and down inside the the WG,s body runs flush with the walls. So any protrusion into the chamber, like the threaded end of the barb interferes with the motion of the piston.
It may be possible to install a smaller barb into one of the vent holes, but did not look very feasible.
So chalk it up to a learning experience.
Sox
Old 10-20-2020, 09:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #156 (permalink)
This is where the Tial 46 is ideal, except for the price!!! $500!!
Mike G.
Old 10-20-2020, 02:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #157 (permalink)
Super Moderator
nize's Avatar
sox; it looks like you have a tial wg sitting on your bench, but you're trying to frankenstein the stock wg? why don't you just use the tial!?!?
also, don't feel bad about failing to frankenstein the stock wg into a dual-port, many have already tried and failed, which is why the tial wg is the solution.
lindsey has a successful halfway-stock dual-port conversion but it costs almost as much as a tial:
Old 10-31-2020, 03:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #158 (permalink)
soxnail's Avatar
Nize cause it's more fun
Sox
Old 10-31-2020, 03:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #159 (permalink)
Super Moderator
nize's Avatar
also, make sure you don't get a counterfeit tial!
TiAL Sport - Spotting a Counterfeit TiAL
fake vs real how-to:
https://www.youtube.com/watch?v=__Jzk0XXvr4
fake vs real teardown:
https://www.youtube.com/watch?v=2nOPLxln5Ec
Old 10-31-2020, 03:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #160 (permalink)
