Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
All Spooled Up
The "final solution" for (AFM) intake upgrade.
ral weeks ago, I posted a pic of the deletion of the stock airbox/snorkle and J-boot. But that setup left one thing to be desired. And that would be the ability to draw air from somewhere other than the hot engine compartment. The germans are very "crafty" at coming up with solutions, but if I may brag a bit, I think I out did them on this one. First, you should probably read this post:
Pic of J-boot delete.
And maybe this one too:
air intake
Here are a pair of pics of the AFM with the cold air intake:
The flex pipe (with coupler) and the folded cone filter (which is too beat to use, now) were purchased at AZ (spectre brand). The filter was placed inside of the fender, with the rubber part sticking out into the engine compartment. It was mounted via sheet metal screws from inside the engine compartment. The plastic end of the alternator intake snorkel had to be notched out in order to fit the filter as I described. That is the dirty (lazy man's) method. One could opt for relocating it about an inch or so away from it's stock location, so as not to have to cut into it.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 02-17-2010, 07:11 AM
Super Moderator
nize's Avatar
wouldn't the corrugations in the flex pipe disturb air flow through the pipe?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 02-18-2010, 10:41 AM
+1... you might want to check the air flow numbers on that contraption before anointing yourself smarter than porsche engineers.
Old 02-18-2010, 04:06 PM
All Spooled Up
I'm no expert in fluid dynamics, or anything, but it probably does. To what extent, would be the question. It IS 3" pipe though - compare that to the size of the stock snorkel end that goes into the fender. If you could get a piece of hardpipe bent for a good fit in place of the flexpipe, that would definitely be a better option. Since I am already well beyond using the stock AFM, I am just trying to put ideas out there for others to work with and perfect, for their own benefit.
Old 02-18-2010, 04:10 PM
All Spooled Up
Naw, all it takes is a little nerve, and maybe some narcissism.
Old 02-18-2010, 04:18 PM
Or this,
Which is soon to be for sale, as I go to a stand alone setup.
Pm me if interested
Old 03-09-2010, 03:11 PM
your average wrencher...
mmmmm, looks good! lol hey, any more info about your upper strut mounts? kla's? you like?
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 03-09-2010, 05:11 PM
