Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Porsche Enthusiast
porsche na-t's Avatar
951 & 951s computers and injectors
Since I'm selling my turbo setup and returning to stock I'm thinking about converting my 951 to an S. Are the computers interchangable beside the pin count? And are the injectors the same?
1987 Porsche 944 Turbo
2005 Subaru Outback
2005 Volvo S60 Turbo AWD
Old 05-03-2010, 10:28 AM
In the Fires of Hell.....
kdjones2000's Avatar
Yours is a 24 pin DME, the TS is a 28 pin DME. KLR's are basically the same, but with a different chip in each.
Injectors are all the same.
Cheers, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 05-03-2010, 12:47 PM
Rogue Tuning
Rogue_Ant's Avatar
Computers are interchangeable. They switch to the 28pin DME somewhere around 88, so it is possible that you could have a 28pin DME - if yours is a really late '87.
Yep, injectors are the same.
KLR is the same - very slight differences in chip, but nothing of any consequence.
-Rogue
-Joshua
www.RogueTuning.com
Old 05-05-2010, 01:37 AM
The switch to 28 pin DME happened in the '88 model year, not '87.
He should have a 24 pin DME.
Old 05-05-2010, 04:18 AM
Rogue Tuning
Rogue_Ant's Avatar
What he should have and what he has are two different things...
The only way to be sure is to open the DME and check.
-Joshua
www.RogueTuning.com
Old 05-05-2010, 07:03 AM
Your turbo would be a k26/6. The S cars have a k26/8 with a larger hotside. The S cars also had larger intake valves in the head.
Old 05-05-2010, 03:13 PM
Rogue Tuning
Rogue_Ant's Avatar
No - the Turbo S had the same size valves. The '89 944 S (non-turbo) had larger intake valves.
-Joshua
www.RogueTuning.com
Old 05-05-2010, 03:14 PM
Not from what I understand. I haven't had my head off to compare but was told there was a difference.
Old 05-05-2010, 03:24 PM
Rogue Tuning
Rogue_Ant's Avatar
Lol, well believe what you want...
But the turbo S head is the same as the turbo - only the 944S had larger intake valves.
-Joshua
www.RogueTuning.com
Old 05-05-2010, 05:23 PM
What's written in the shop manual or some tech bulletin is that the Turbo S exhaust valve has a slightly smaller boss or neck on the valve to improve flow at the very high end of the RPM range.
That being said, Pauerman has measured both valves and told me that they are pretty much the same.
Cheers, Keith
Old 05-05-2010, 05:46 PM
