Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
All Spooled Up
Explanation of where cam# is located.
The 5-digit # is located right between the exhaust and intake cams of cylinder #2. Rotationally speaking, it is lined up exactly, with the lobe peak of the #2 intake cam (4th cam back, on the shaft). Oops, this should have gone into the n/a forum, as it has vastly larger readership.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 06-14-2010, 08:42 AM
All Spooled Up
I forgot to mention, that if you remove the 3rd plug on the cam tower, and orient the shaft so that the #2 intake lobe is pointing straight up, the # should be right there.
Old 06-14-2010, 09:59 AM
