Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
All Spooled Up
Blink code tester doesn't blink.
I have a blink code tester installed, but not sure if it is working correctly. LR says that if you disconnect the TPS and drive around the block, or run the engine at over 1500rpm for more than 30 seconds, it should blink a 4-1 code.
But all I get when I disconnect the TPS is a steady on light - no blinking. Might I have a bad KLR?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 08-08-2010, 05:51 PM
Rogue Tuning
Rogue_Ant's Avatar
Your not shutting off the car correct? I doubt you have a bad KLR.
-Joshua
www.RogueTuning.com
Old 08-08-2010, 05:57 PM
Super Moderator
nize's Avatar
are you sure you connected it correctly? steady on usually means you plugged it into power+ground instead of test+ground.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 08-09-2010, 01:36 PM
All Spooled Up
Even if it goes out after I plug the TPS back in?
Old 08-12-2010, 05:30 AM
