Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Heater Valve: Car off, does it default to open?
OK, here's a question, when the car is not running, is the vacuum operated heater valve in the open position or closed?
I picked up a Stant cooling system pressure tester (amazing tool by the way) and when I use it to bleed the system, I want to be sure I'm getting to the heater core as well.
Thanks guys.
Old 02-15-2011, 06:36 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
You need the car running and at operting temp to properly bleed the cooling system. I also helps to raise the front of the car a bit when doing the bleed. Heater valve must be OPEN when bleeding.
If you don't have the car running and at operating temp you will not get all the air out of the system. There is a pocket in the back of the head that traps air, and if not properly bled, you will end up with a "hot spot" and ultimately a blown head gasket.
Proper bleeding of the system is another one of the "MUST DO" things on these cars, just like timely timing/balance belt replacement.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 02-16-2011, 07:02 PM
Under the hood is in pieces, I've just built up the coolant system with all new hoses and want to check for leaks before I assemble much more. Its easy to get to the hoses now if I need to tighten or adjust. I'll do a full nose up hot bleed in the spring.
Old 02-17-2011, 05:22 PM
I'm pretty sure the valve is open if there is no vacuum to it. With the car off, the coolant should go through the valve, not sure about the heater core ( exchanger) though. I would suspect that it does.
Bruce P.
2011 Cayman Base, LSD, Sport Chrono.
1988 951 totaled and missed
"You're the best I ever had" --JJ Cale
Old 02-18-2011, 09:11 PM
Thanks, that seems logical to me, but I've been fooled before by illogical occurences on my 951.
1987 951 ROW
Old 02-22-2011, 07:39 AM
All Spooled Up
Thanks guys.
Without even seeing the pressure tester, I must agree that it is amazing, if it can also be used to bleed the system out. Looks like you have your answer, anyways.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 03-05-2011, 05:59 AM
