Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Still not getting full boost!
my 86 turbo is still only getting 6-7psi of boost. I have replaced the vacuum lines, and pretty much anything rubber under the intake, and did the venturi delete and deleted that metal thing. I was going to replace the cv, but the one in there looked better than the one I bought (the plastic ring was still white even. Had to have been replaced recently). All of this gives me a better idle, but still the same boost issue. If i clamp the wastegate hose, I can easily get full boost, but running regular, I will boost nice until 6-7psi and then it just stops, and even falls off sometimes. My turbo spun nice, and i'm pretty sure it has no play. I wiggled it while the intake is off. Now I don't know what to do!
Old 03-27-2012, 05:09 AM
Super Moderator
nize's Avatar
it sounds like you have a leak in the intake. check the bov?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 03-28-2012, 11:10 AM
I'd like to follow this thread. Dealing with same issue. Have bought everything vacuum related, including cycling valve and KLR line, for replacement, which I'm doing next week.
I have found a couple of very hard-to-find articles on the subject which I will post once I find out where I put them.
Old 04-04-2012, 04:03 PM
