| Registered User |
				Still not getting full boost!
			my 86 turbo is still only getting 6-7psi of boost.  I have replaced the vacuum lines, and pretty much anything rubber under the intake, and did the venturi delete and deleted that metal thing.  I was going to replace the cv, but the one in there looked better than the one I bought (the plastic ring was still white even.  Had to have been replaced recently).  All of this gives me a better idle, but still the same boost issue.  If i clamp the wastegate hose, I can easily get full boost, but running regular, I will boost nice until 6-7psi and then it just stops, and even falls off sometimes.  My turbo spun nice, and i'm pretty sure it has no play.  I wiggled it while the intake is off.  Now I don't know what to do!
|  03-27-2012, 04:09 AM |
| Super Moderator |
			it sounds like you have a leak in the intake. check the bov?
				__________________ '89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) | ||
|  03-28-2012, 10:10 AM |
| Registered User Join Date: Dec 2010
			I'd like to follow this thread.  Dealing with same issue.  Have bought everything vacuum related, including cycling valve and KLR line, for replacement, which I'm doing next week. I have found a couple of very hard-to-find articles on the subject which I will post once I find out where I put them. | ||
|  04-04-2012, 03:03 PM |
