Cat delete question
I recently had to remove my cat as the guts inside fell apart. Currently the O2 sensor is still plugged in. Should I disconnect it and run in open loop or leave it as is? Thanks
The o2 sensor is pre cat so changing the cat wont effect how the o2 sensor operates.
Alexander '75 911S Targa '86 951 SOLD |
There is no substitute..
No problem, as Sketchers said, Oxygen sensor can be found under the hood near of the turbo. You can see it. He is wayyyyyyy far from the cat
--Matt I couldn't find the sports car of my dreams, so I built it myself Porsche 951 1988 - More than 305 RWHP & 350 RWTorque |
Porsche 944S Club Sport
Tberry1:
Only good as a short term solution (Cat removed). Car was never designed to operate without O2 for close loop operation. Loss of low end pre-boost torque. Not good for street... Recommend replacing with a high flow & quality Stainless Steel Bullet style cat. They run ~$100-250 Typical. and Yes it does have an effect on the O2 Temps are different... Later...
Guru944 ![]() 2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport. 1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo. http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions. Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful. |
