Porsche 944S Club Sport
All oem intake manifolds leak because of a design flaw.....get it fixed/modified. Then work from there. Vacuume /boost is off until properly addressed.
Pm me for details. Later.
Guru944 ![]() 2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport. 1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo. http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions. Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful. |
Thanks Mike G. |
Anything after turbo doesn't matter as much. Exhaust issues is typically between header and turbo. Dual-layer crossover section can get clogged by inner-layer melting. Usual test is to see if golf-ball can be rolled through. Many 951s have collapsed crossover.
Also clogged cat can reduce boost, but usually only 1-2 psi. Test max-boost by driving with catalytic section removed. You'll also want to test wastegate as well. Remove it and apply pressure to diaphragm (bicycle hand-pump w/gauge) and measure two values: 1. pressure where wastegate valve just begins to open 2. pressure where wastegate valve is fully open. These numbers will tell you condition of wastegate. There are actually several ways to increase spring-rate of factory wastegate if it opens too easily. I've used factory turbo & wastegate up to 25psi without any issues (custom chip-mapping or aftermarket EFI system needed). Last edited by DannoXYZ; 10-13-2019 at 01:19 PM.. |
Thanks Mike G. Last edited by Mike Goebel; 10-13-2019 at 11:20 AM.. |
Measure actual values on yours and we can compare.
Max-opening is about 13-15mm on wastegate valve. Also test your CBV - compressor bypass valve. Simple test is to blow through each big port. Should not flow pressure in either direction. If it has ruptured diaphragm, you'll hear fluttering or turkey-gobbling sound when building boost or shifting. Replace with part# 993.110.337.50 which is little stronger with brass-reinforced diaphragm. Last edited by DannoXYZ; 10-13-2019 at 04:00 PM.. |
Ok, that great testing! Yes, perfectly good wastegate. Weak ones tend to start opening at 2-3psi and fully open by 5-6psi, so yours is in great shape. To regulate to stock 1.6-bar boost, wastegate only needs to open halfway, about 5-6mm.
I suspect combination of issues: 1. Cycling-valve is most likely culprit as confirmed by your pinched-hose test. By default, cycling-valve is fully-open and letting all pressure to wastegate and dumping boost. Working cycling valve is controlled by KLR and diverts pressure back to intake (away from wastegate) and allowing boost to build. Getting 1.8-bar with pinch test shows either KLR or CV is not working. You can test KLR’s CV control line with noid-light and see if it’s sending signal to CV 2. CBV - apply vacuum to little port. Can you see plunger opening bottom port? Does it hold vacuum and keep bottom port open? 3. Collapsed crossover pipe. This is next most-common source of low boost as exhaust is not hitting turbo hard enough to generate boost. Might be only slightly collapsed as you’re still able to get 1.8-bar boost. 4. Clogged cat is also very possible. Easy to test by removing catalytic, and holding rear exhaust up with coat-hanger. Test pinched-hose test again in remote area (loud) and see if you get 2.0-2.2 bar boost. Not likely as DME will cut off fuel at 1.8-1.9 bar. But i’ve seen many that won’t do that until 2.1-2.2 bar 5. Worn turbo. I’ve seen many of these. Do you have oil pooled up on back of intske-valves when car is stopped? Do you get grey/blue smoke when getting on boost? Most common cause of worn turbos is inadequate cooling. Does turbo water pump work to cool turbo for 2-5 minutes after stopping? Have you verified that water-port for turbo on water-pump has been drilled out? I’ve seen many, many of these in default 944NA blocked-off state. Try to feel and measure radial and axial-play of turbo-shaft at compressor wheel nut. If it’s more like than 1.25-1.50mm in any direction, turbo’s kaput! Last edited by DannoXYZ; 10-15-2019 at 10:26 AM.. |
Can the BOV by itself be the cause of the low boost problem? Thanks Mike G. Last edited by Mike Goebel; 10-15-2019 at 05:00 PM.. |
It's possible bad CBV is sending boost around to turbo-inlet instead of into engine. Simple test is remove it and plug vacuum-hose with bolt and two big hoses with cork or something. Then gently try some test-runs. Don't let up throttle too quickly as shock-wave bouncing off closed throttle-plate can shatter turbo's compressor-blades without CBV installed. If it's not holding vacuum, then definitely needs replacing anyway.
Cycling-valve and collapsed crossover most likely culprits at this point. Last edited by DannoXYZ; 10-17-2019 at 02:48 PM.. |
It may be locked up inside and still click. Really need to test flow-conditions of CV. Be really careful with plastic nipples on CV. Pull hoses straight off, do not bend them or they'll break nipples off CV. Might be safest to cut hard crispy hoses off with dremel and replace with new soft hoses. I like to lay triangular filet of epoxy where nipples join body of CV to reinforce. Can attach hose to port C and blow in it and see where it comes out. Power on CV no more than 5-10s at time to avoid overheating it. To test CV:
1. With no power-applied to CV, confirm you have flow between ports C and W 2. With power-applied to CV, confirm you DO NOT have flow between ports C and W 3. With power-applied to CV, confirm you DO have flow between ports C and R If you have defective CV, don't need to use crappy old plastic part. Get modern all-metal boost-solenoid: https://www.aemelectronics.com/products/sensors-connectors-accessories/boost-control-solenoid Which is actually just MAC control valve As for testing signal, not sure duration is high enough to light up test light (it's PWM signal like injectors). Wouldn't hurt to try. Noid-light has duration-extending circuitry to ensure it lights up with shortest of signals. Oscilloscope would also work. Last edited by DannoXYZ; 10-17-2019 at 11:07 PM.. |
Damn! I wish I didn't have to work today!!
Thanks Mike G. |
Thanks Mike G. Last edited by Mike Goebel; 10-18-2019 at 05:06 PM.. |
Still possibility your crossover is slightly restrictive as well. |
Got this from a German Forum!
The timing valve has no diaphragm, it clocks a piston. The line C-W is always open. Via the piston, the line R is released intermittently to lower the pressure in C-W. Test the timing valve You should blow in "R". If the cycle valve is closed, "R" is also closed (almost). The full charge pressure is therefore on the wastegate. If 12V is applied to the timing valve, "R" is open. The boost pressure is for the most part back into the intake area and the control pressure on the wastegate is minimal. Thanks Mike G. |
RE-tested CV just to make sure and the old CV is fine. New BOV and sealed the throttle shaft. Did a test run still only 1.4 BAR. Hmm! Going to check the boost press with a gauge now. Wonder if the stock boost gauge has a way to be calibrated?
Thanks Mike G. |
Checked boost pressure with crappy Harbor Freight test gauge that has a max press of 10 psi. Looked like about 9 psi max in 3rd gear. Pinched off WG hose, again, and the gauge read 1st-8.5, 2nd-10ish, 3rd-pegged at 10+psi.
What does the vacuum typically read on these beasts? Thanks Mike G. |
Super Moderator
it should be -18 to -20 inHg vacuum at idle.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
What kind of boost do most see when pinching off the WG hose with a stock engine?
Thanks Mike G. |
