Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
GLO (guest)
Guest
Posts: n/a
I have to replace the fuse relay panel on a 1985/2 944. Does any one have any good tip for doing this job.
Gary
This post was auto-generated based upon a question asked on our tech article page here:
Old 03-11-2015, 07:14 PM
Nick at Pelican Parts's Avatar
We don't currently have that tech article. If we get a chance to perform the procedure, we will be sure to document it.
I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
In the Fires of Hell.....
kdjones2000's Avatar
It's not that difficult to do on the late cars.
First, disconnect your battery.
Document where the relays are located on the panel, then remove them, or at least the ones near the corners. You should then find 2 screws in diagonal corners with knurled ends on them.
Unscrew those and then you can lift the entire panel up, enough so that you can release the (I think) 2 catches underneath the fuse panel that hold in the many connectors attached to the underside of the fuse panel. Each one of those connectors is labeled with a letter, and the fuse panel has a matching letter on it as well.
Unplug the few remaining wires and the panel should come right out.
Look at posts #7 and 8 in this thread for some pictures. You will probably have to zoom out in your browser to see them as they came in pretty large for some reason.
Euro Foglight Conversion
Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 03-11-2015, 07:43 PM
kens_74_911s's Avatar
Fb
Good luck, Keith
The "latches" Keith mentions is only one and more like A long locking gate that slides in a track and extends front to back on the fuse box housing locking all the connectors into their positions.
I have a good fuse box assembly with relays if you need one ...
K
You can see the sliding locking gate in this image near center between the rods of connectors.
(not the same fuse box as above this one already sold)
Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s NA Widebody /96 BMW 750iL /99 BMW 328i/ 2018 BMW X3
81 VW Caddy Pickup X2 now...
84,85x2 .86,87,944. 82-924,88-924s parted with inventory!
68, 70, 72, 73, 911~ 70,73 914 past P/cars
Old 03-13-2015, 09:00 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
I decided to explore the innards of one of my fuse/relay boxes because of a damaged terminal inside. My, God, what an adventure that was. There's several layers of copper runs, with all kinds of twists and bends and then to put it all together so each pin, as shown above, had to come through all the slots. Odds against it, I actually got it all put back together and it was a success. Lesson: Don't take the darn thing apart.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 03-15-2015, 11:33 AM
